  1. Need some help with a dvd im trying to rip.
    Its called The Animal and i cant seem to get the very last chapter.
    It goes fine up to the one year later bit and then thats the end of the movie. But this leaves out the last few minutes of the movie.
    I need help quick as the dvd is going back tomorrow.
    The programs i use are,
    Smart Ripper 2.41
    Dvd2Avi
    TMPGENc
    So if someone could tell me how to get the last few minutes that would be great.
    Cheers.
    Doh Doh Doh!!!
  2. if you have ripped it successfully, you can check by opening up dvd2avi, and scrol lthe time bar window once you loaded up the vob files, sroll al lthe way to the end, if you see film credits, you know you got all of the movie,
    so either the frameserver has got the nd set too early ( and the bracketing source feature ) or in tmpegenc you got the souce set too early in the source windows and not all the way to the end
  3. tried ripping it again it still wont get the last chapter any help would be great.
    Doh Doh Doh!!!
  4. so you reripped and checked the vob files in dvd2avi or power dvd to see what you all got ?
    have you tried another dvd ripper like dvd decryptor ?
  5. i ripped the animal successfully...however, the same thing happened to me when i ripped w/ smartripper...for some reason, smartripper leaves a little bit off at the end..
    however, dvddecryptor was able to rip it completely...just make sure you goto options and ENABLE MULTI-ANGLE PROCESSING...otherwise, you might leave some multi-angles intact in your vob files
  6. Cheers for the info will try that program and see if it works.
    Doh Doh Doh!!!
