The issue arises also with Ubuntu 22.04 and ffmpeg n6.1.1! Nobody experiencing this issue ?? Any solution hints?
never used the option (I don't capture stuff), but it is from libavformat/dashdec.c ,
Code:static const AVOption dash_options[] = { {"allowed_extensions", "List of file extensions that dash is allowed to access", OFFSET(allowed_extensions), AV_OPT_TYPE_STRING, {.str = "aac,m4a,m4s,m4v,mov,mp4,webm,ts"}, INT_MIN, INT_MAX, FLAGS}, { "cenc_decryption_key", "Media decryption key (hex)", OFFSET(cenc_decryption_key), AV_OPT_TYPE_STRING, {.str = NULL}, INT_MIN, INT_MAX, .flags = FLAGS }, {NULL} };
So the libav version you are using might be the problem.users currently on my ignore list: deadrats, Stears555 -
Hi thanks, I found this too, but, do you know how this could be used as a command line option in ffmpeg? It seems to me that
Code:dash_options
Code:dash_class
Code:ff_dash_demuxer
Code:#define OFFSET(x) offsetof(DASHContext, x) #define FLAGS AV_OPT_FLAG_DECODING_PARAM static const AVOption dash_options[] = { {"allowed_extensions", "List of file extensions that dash is allowed to access", OFFSET(allowed_extensions), AV_OPT_TYPE_STRING, {.str = "aac,m4a,m4s,m4v,mov,mp4,webm,ts"}, INT_MIN, INT_MAX, FLAGS}, { "cenc_decryption_key", "Media decryption key (hex)", OFFSET(cenc_decryption_key), AV_OPT_TYPE_STRING, {.str = NULL}, INT_MIN, INT_MAX, .flags = FLAGS }, {NULL} }; static const AVClass dash_class = { .class_name = "dash", .item_name = av_default_item_name, .option = dash_options, .version = LIBAVUTIL_VERSION_INT, }; const AVInputFormat ff_dash_demuxer = { .name = "dash", .long_name = NULL_IF_CONFIG_SMALL("Dynamic Adaptive Streaming over HTTP"), .priv_class = &dash_class, .priv_data_size = sizeof(DASHContext), .flags_internal = FF_FMT_INIT_CLEANUP, .read_probe = dash_probe, .read_header = dash_read_header, .read_packet = dash_read_packet, .read_close = dash_close, .read_seek = dash_read_seek, .flags = AVFMT_NO_BYTE_SEEK, };
what is the ffmpeg command that you are using ??
see this thread page 2 post #33 - https://forum.videohelp.com/threads/400424-Downloading-DRM-protected-video-and-decrypt...nown-key/page2 -
Like I wrote, I never used 'cenc_decryption_key', the used demuxer in ffmpeg will normally be decided depending on the input file.
Calling 'ffmpeg -demuxers' I get:
Code:... D dash Dynamic Adaptive Streaming over HTTP ...
I agree october262: What does your command line look like?users currently on my ignore list: deadrats, Stears555
How to send streamlink output into ffmpeg for further processing (ubuntu)?
By BosseB in forum Video Streaming DownloadingReplies: 1Last Post: 30th Jan 2024, 09:20 -
cenc_decryption_key with 2 keys ??
By dromicron in forum Video Streaming DownloadingReplies: 4Last Post: 18th Jun 2022, 10:05 -
how do i add libx264 and hevc to ffmpeg when i compile ffmpeg for ubuntu 21
By oduodui in forum Newbie / General discussionsReplies: 2Last Post: 17th Jul 2021, 04:12 -
FFMPEG on Ubuntu server introducing green screen in the intro for IOS devic
By Hyder-caravel in forum Video ConversionReplies: 1Last Post: 15th Mar 2021, 10:39 -
x264: unrecognized option `--fade-compensate'
By tee_trea in forum Video ConversionReplies: 3Last Post: 10th Jan 2021, 15:20
