Hi all,
I still have a much used old pc with an Intel Core i7-2600K on ASUS P8Z77-V mobo, running Windows 7 64 bit. Which version of x265.exe - 64 bit would you recommend?
Reason I'm asking is latest version of StaxRip threw me an error. Replacing SR native's with x265 "Product version 3.5+104-1634ada16" (from MeGUI) did the trick. Though it made me wondering if newer/better versions for my cpu would be available.
The x265 is quite mature product at this moment, so don't expect any really noticeable improvements of quality/speed in newer versions, it's just minor bugfixes.
I would upgrade my pc which i did,i had a 2600k and it was the best cpu back then but newer ones are 10x faster.
I do realize the pc is dated, if not ancient. Already planning to build a new one, I'd like to keep it alongside though.
Thanks for your replies, guys. -
You may realize a performance benefit by using a version of x265 tuned for your cpu. It looks like your cpu has AVX extensions but StaxRip bundles the Mod-by-Patman AVX2 version, which your cpu can't run. If you want to use that mod, there is an AVX version you could try.
https://github.com/Patman86/x265-Mod-by-Patman/releasesPB
Recommended settings for X265
By Cazz in forum Video ConversionReplies: 3Last Post: 5th Nov 2022, 08:47 -
high core count cpu for x265 encoding good idea?
By sonyzz in forum ComputerReplies: 18Last Post: 6th Mar 2021, 17:57 -
CPU benchmark (HardInfo) - what result most relevant for x265 encoding
By Prototype v1.0 in forum ComputerReplies: 5Last Post: 24th Jan 2021, 19:41 -
XMedia Recode recommended settings for x264 and x265 encoders
By anet88 in forum EditingReplies: 1Last Post: 15th Nov 2020, 11:06 -
Handbrake x265 encoding cpu doubt
By Sephiroth in forum Video ConversionReplies: 3Last Post: 17th May 2019, 08:29
