If I use -vf format=rgb8 when making images with ffmpeg, will the result be lossy even with lossless formats like PNG? If so, how do I fix that? What supported pixel formats are lossless with RGB display, other than the titular format itself?
"RGB8" is 8 bits total . 3 red, 2 green, 2 blue . It will be very lossy. It's not supported by PNG .
You probably mean "rgb24" . 8 red, 8 green, 8 blue . Or 8bits per channel component
You can check what pixel formats are supported by various encoders in ffmpeg using ffmpeg -h encoder=blah
8bit RGB displays would use RGB24, or GBRP (RGB planar, 8 bit depth) . There are other variations such as bgr24, bgr0, 0bgr, rgb0, 0rgb, a few others. They all mean 8bit per channel RGB , but are arranged slightly differently -
ffmpeg is quite descriptive on supported pixel formats:
Code:--------------- ffmpeg -pix_fmts --------------- --------------- Pixel formats: I.... = Supported Input format for conversion .O... = Supported Output format for conversion ..H.. = Hardware accelerated format ...P. = Paletted format ....B = Bitstream format FLAGS NAME NB_COMPONENTS BITS_PER_PIXEL BIT_DEPTHS ----- IO... yuv420p 3 12 8-8-8 IO... yuyv422 3 16 8-8-8 IO... rgb24 3 24 8-8-8 IO... bgr24 3 24 8-8-8 IO... yuv422p 3 16 8-8-8 IO... yuv444p 3 24 8-8-8 IO... yuv410p 3 9 8-8-8 IO... yuv411p 3 12 8-8-8 IO... gray 1 8 8 IO..B monow 1 1 1 IO..B monob 1 1 1 I..P. pal8 1 8 8 IO... yuvj420p 3 12 8-8-8 IO... yuvj422p 3 16 8-8-8 IO... yuvj444p 3 24 8-8-8 IO... uyvy422 3 16 8-8-8 ..... uyyvyy411 3 12 8-8-8 IO... bgr8 3 8 3-3-2 .O..B bgr4 3 4 1-2-1 IO... bgr4_byte 3 4 1-2-1 IO... rgb8 3 8 2-3-3 .O..B rgb4 3 4 1-2-1 IO... rgb4_byte 3 4 1-2-1 IO... nv12 3 12 8-8-8 IO... nv21 3 12 8-8-8 IO... argb 4 32 8-8-8-8 IO... rgba 4 32 8-8-8-8 IO... abgr 4 32 8-8-8-8 IO... bgra 4 32 8-8-8-8 IO... gray16be 1 16 16 IO... gray16le 1 16 16 IO... yuv440p 3 16 8-8-8 IO... yuvj440p 3 16 8-8-8 IO... yuva420p 4 20 8-8-8-8 IO... rgb48be 3 48 16-16-16 IO... rgb48le 3 48 16-16-16 IO... rgb565be 3 16 5-6-5 IO... rgb565le 3 16 5-6-5 IO... rgb555be 3 15 5-5-5 IO... rgb555le 3 15 5-5-5 IO... bgr565be 3 16 5-6-5 IO... bgr565le 3 16 5-6-5 IO... bgr555be 3 15 5-5-5 IO... bgr555le 3 15 5-5-5 ..H.. vaapi 0 0 0 IO... yuv420p16le 3 24 16-16-16 IO... yuv420p16be 3 24 16-16-16 IO... yuv422p16le 3 32 16-16-16 IO... yuv422p16be 3 32 16-16-16 IO... yuv444p16le 3 48 16-16-16 IO... yuv444p16be 3 48 16-16-16 ..H.. dxva2_vld 0 0 0 IO... rgb444le 3 12 4-4-4 IO... rgb444be 3 12 4-4-4 IO... bgr444le 3 12 4-4-4 IO... bgr444be 3 12 4-4-4 IO... ya8 2 16 8-8 IO... bgr48be 3 48 16-16-16 IO... bgr48le 3 48 16-16-16 IO... yuv420p9be 3 13 9-9-9 IO... yuv420p9le 3 13 9-9-9 IO... yuv420p10be 3 15 10-10-10 IO... yuv420p10le 3 15 10-10-10 IO... yuv422p10be 3 20 10-10-10 IO... yuv422p10le 3 20 10-10-10 IO... yuv444p9be 3 27 9-9-9 IO... yuv444p9le 3 27 9-9-9 IO... yuv444p10be 3 30 10-10-10 IO... yuv444p10le 3 30 10-10-10 IO... yuv422p9be 3 18 9-9-9 IO... yuv422p9le 3 18 9-9-9 IO... gbrp 3 24 8-8-8 IO... gbrp9be 3 27 9-9-9 IO... gbrp9le 3 27 9-9-9 IO... gbrp10be 3 30 10-10-10 IO... gbrp10le 3 30 10-10-10 IO... gbrp16be 3 48 16-16-16 IO... gbrp16le 3 48 16-16-16 IO... yuva422p 4 24 8-8-8-8 IO... yuva444p 4 32 8-8-8-8 IO... yuva420p9be 4 22 9-9-9-9 IO... yuva420p9le 4 22 9-9-9-9 IO... yuva422p9be 4 27 9-9-9-9 IO... yuva422p9le 4 27 9-9-9-9 IO... yuva444p9be 4 36 9-9-9-9 IO... yuva444p9le 4 36 9-9-9-9 IO... yuva420p10be 4 25 10-10-10-10 IO... yuva420p10le 4 25 10-10-10-10 IO... yuva422p10be 4 30 10-10-10-10 IO... yuva422p10le 4 30 10-10-10-10 IO... yuva444p10be 4 40 10-10-10-10 IO... yuva444p10le 4 40 10-10-10-10 IO... yuva420p16be 4 40 16-16-16-16 IO... yuva420p16le 4 40 16-16-16-16 IO... yuva422p16be 4 48 16-16-16-16 IO... yuva422p16le 4 48 16-16-16-16 IO... yuva444p16be 4 64 16-16-16-16 IO... yuva444p16le 4 64 16-16-16-16 ..H.. vdpau 0 0 0 IO... xyz12le 3 36 12-12-12 IO... xyz12be 3 36 12-12-12 IO... nv16 3 16 8-8-8 ..... nv20le 3 20 10-10-10 ..... nv20be 3 20 10-10-10 IO... rgba64be 4 64 16-16-16-16 IO... rgba64le 4 64 16-16-16-16 IO... bgra64be 4 64 16-16-16-16 IO... bgra64le 4 64 16-16-16-16 IO... yvyu422 3 16 8-8-8 IO... ya16be 2 32 16-16 IO... ya16le 2 32 16-16 IO... gbrap 4 32 8-8-8-8 IO... gbrap16be 4 64 16-16-16-16 IO... gbrap16le 4 64 16-16-16-16 ..H.. qsv 0 0 0 ..H.. mmal 0 0 0 ..H.. d3d11va_vld 0 0 0 ..H.. cuda 0 0 0 IO... 0rgb 3 24 8-8-8 IO... rgb0 3 24 8-8-8 IO... 0bgr 3 24 8-8-8 IO... bgr0 3 24 8-8-8 IO... yuv420p12be 3 18 12-12-12 IO... yuv420p12le 3 18 12-12-12 IO... yuv420p14be 3 21 14-14-14 IO... yuv420p14le 3 21 14-14-14 IO... yuv422p12be 3 24 12-12-12 IO... yuv422p12le 3 24 12-12-12 IO... yuv422p14be 3 28 14-14-14 IO... yuv422p14le 3 28 14-14-14 IO... yuv444p12be 3 36 12-12-12 IO... yuv444p12le 3 36 12-12-12 IO... yuv444p14be 3 42 14-14-14 IO... yuv444p14le 3 42 14-14-14 IO... gbrp12be 3 36 12-12-12 IO... gbrp12le 3 36 12-12-12 IO... gbrp14be 3 42 14-14-14 IO... gbrp14le 3 42 14-14-14 IO... yuvj411p 3 12 8-8-8 I.... bayer_bggr8 3 8 2-4-2 I.... bayer_rggb8 3 8 2-4-2 I.... bayer_gbrg8 3 8 2-4-2 I.... bayer_grbg8 3 8 2-4-2 I.... bayer_bggr16le 3 16 4-8-4 I.... bayer_bggr16be 3 16 4-8-4 I.... bayer_rggb16le 3 16 4-8-4 I.... bayer_rggb16be 3 16 4-8-4 I.... bayer_gbrg16le 3 16 4-8-4 I.... bayer_gbrg16be 3 16 4-8-4 I.... bayer_grbg16le 3 16 4-8-4 I.... bayer_grbg16be 3 16 4-8-4 ..H.. xvmc 0 0 0 IO... yuv440p10le 3 20 10-10-10 IO... yuv440p10be 3 20 10-10-10 IO... yuv440p12le 3 24 12-12-12 IO... yuv440p12be 3 24 12-12-12 IO... ayuv64le 4 64 16-16-16-16 ..... ayuv64be 4 64 16-16-16-16 ..H.. videotoolbox_vld 0 0 0 IO... p010le 3 15 10-10-10 IO... p010be 3 15 10-10-10 IO... gbrap12be 4 48 12-12-12-12 IO... gbrap12le 4 48 12-12-12-12 IO... gbrap10be 4 40 10-10-10-10 IO... gbrap10le 4 40 10-10-10-10 ..H.. mediacodec 0 0 0 IO... gray12be 1 12 12 IO... gray12le 1 12 12 IO... gray10be 1 10 10 IO... gray10le 1 10 10 IO... p016le 3 24 16-16-16 IO... p016be 3 24 16-16-16 ..H.. d3d11 0 0 0 IO... gray9be 1 9 9 IO... gray9le 1 9 9 IO... gbrpf32be 3 96 32-32-32 IO... gbrpf32le 3 96 32-32-32 IO... gbrapf32be 4 128 32-32-32-32 IO... gbrapf32le 4 128 32-32-32-32 ..H.. drm_prime 0 0 0 ..H.. opencl 0 0 0 IO... gray14be 1 14 14 IO... gray14le 1 14 14 IO... grayf32be 1 32 32 IO... grayf32le 1 32 32 IO... yuva422p12be 4 36 12-12-12-12 IO... yuva422p12le 4 36 12-12-12-12 IO... yuva444p12be 4 48 12-12-12-12 IO... yuva444p12le 4 48 12-12-12-12 IO... nv24 3 24 8-8-8 IO... nv42 3 24 8-8-8 ..H.. vulkan 0 0 0 ..... y210be 3 20 10-10-10 IO... y210le 3 20 10-10-10 IO... x2rgb10le 3 30 10-10-10 ..... x2rgb10be 3 30 10-10-10 IO... x2bgr10le 3 30 10-10-10 ..... x2bgr10be 3 30 10-10-10 IO... p210be 3 20 10-10-10 IO... p210le 3 20 10-10-10 IO... p410be 3 30 10-10-10 IO... p410le 3 30 10-10-10 IO... p216be 3 32 16-16-16 IO... p216le 3 32 16-16-16 IO... p416be 3 48 16-16-16 IO... p416le 3 48 16-16-16 IO... vuya 4 32 8-8-8-8 I.... rgbaf16be 4 64 16-16-16-16 I.... rgbaf16le 4 64 16-16-16-16 IO... vuyx 3 24 8-8-8 IO... p012le 3 18 12-12-12 IO... p012be 3 18 12-12-12 ..... y212be 3 24 12-12-12 IO... y212le 3 24 12-12-12 ....B xv30be 3 30 10-10-10 IO... xv30le 3 30 10-10-10 ..... xv36be 3 36 12-12-12 IO... xv36le 3 36 12-12-12 ..... rgbf32be 3 96 32-32-32 ..... rgbf32le 3 96 32-32-32 ..... rgbaf32be 4 128 32-32-32-32 ..... rgbaf32le 4 128 32-32-32-32 IO... p212be 3 24 12-12-12 IO... p212le 3 24 12-12-12 IO... p412be 3 36 12-12-12 IO... p412le 3 36 12-12-12 IO... gbrap14be 4 56 14-14-14-14 IO... gbrap14le 4 56 14-14-14-14 ..H.. d3d12 0 0 0
Does YUV video have always the same size? Why RGB would be different?
Google how compression works. These basics are holding you down, looking for a nonsense solutions.
To sum it up (latest month) , now you know to have good looking image, it needs to be about 0.5MB. That depends on picture, whats in it, I just take your example.
So imagine 10 second video image sequence. You'd need 120MB (24fpsx0.5MBx10seconds). When you realize how much of a size would be 10s cut out of your video, you'd realize what you are doing. That 10 second sequence would hardly be more that 40MB. And that's an exaggeration, perhaps anime could be much less than that. -
Meaning quality will look terrible for RGB8 because you have too few bits per channel. It will be posterized and blocky
pal8 is for GIF - quality will be terrible for a PNG
The others have no color, they are greyscale , and the ones with "a" such as ya8 ya16be have an alpha channelLast edited by poisondeathray; 9th Feb 2024 at 17:30.
MPD files and multiple EXO files
By labamba in forum Video Streaming DownloadingReplies: 20Last Post: 29th Dec 2023, 03:16 -
Playing recovered .swf files from a ZOSI H265+ DVR -Recovered Files from HD
By WitsEnd in forum Video ConversionReplies: 1Last Post: 27th Jun 2022, 02:09 -
I need help decrypt movie files (starzplay) , files included !
By Dazzle Cat in forum Video Streaming DownloadingReplies: 1Last Post: 1st Oct 2020, 18:29 -
How do i convert .srt files to .odt files?
By jooj in forum SubtitleReplies: 2Last Post: 25th Dec 2019, 19:32 -
image files Image Files IMG FILES
By Marsia Mariner in forum TestReplies: 9Last Post: 12th May 2019, 21:57
