Page 1 of 3
1 2 3 LastLast
Results 1 to 30 of 84
  1. *** works with many websites, but not all ***
    install
    1- python 3
    2- CDM Device.wvd in the same folder ( included )
    3- install requirements ( pip install -r requirements.txt )
    update v2.
    1- Get license link and headers automatically from curl(bash)
    2- Remove all old tabs
    3- Remove download via n_m3u8dl-re
    [Attachment 82633 - Click to enlarge]
    github: https://github.com/imrsaleh/widevineKeys-GUI
    download: https://files.videohelp.com/u/308429/widevineKeys-GUI-2.zip
  2. Missing logo.ico.
  3. Originally Posted by DPyro View Post
    Missing logo.ico.
    download all files from github
    https://github.com/imrsaleh/widevineKeys-GUI/releases/tag/10.0.0.0.0.0
  4. nice tool mate. thanks for you sharing
  5. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Looks good! Should make things a lot easier
    If you reverse the API calls made when loading a website, you should be able to just enter a video url (the actual page) and perform all needed calls from there automatically.
  6. You are a man of your word. You said that you will share and you have delivered. I respect that.
    Thanks very much for sharing
  7. Looks good! Should make things a lot easier
    Thanks for the suggestion. That would be very good, but due to my limited knowledge of how websites work and how to deal with JavaScript, I stopped at that.
    you're welcome
    enjoy..
  8. Hello, I want to know: What URL do I need to get header and params? MPD, or License?
    Thanks for your program first.
  9. Originally Posted by kienkzz View Post
    headers, params, and cookies are optional and can be found in the license Curl
  10. i know that, thanks for your info
  11. Anonymous
    Guest
  12. Many thanks. Consider to add in a future release automatic PSSH extractor for example from init.mp4
    or from MPD.
  13. Originally Posted by tuskacz View Post
    good
    using command line in 21st century is like using nokia 3310 as a phone, laughable
    all cmd tools should be GUI-ed
    or from MPD.
    maybe in the future
  14. Hi, thank you very much for widevineKeys-GUI, I have a question, I'm trying to test extracting keys, I have everything installed, but every time I test I get the answer "Error: list index out of range", I will add that in WKS I extract keys correctly on the same data. Am I missing something or am I doing it incorrectly?
  15. Originally Posted by maxx123 View Post
    You need CDM in wvd format in device folder
  16. Thank you
    It makes it very easy to use
    But there is a problem with the drmtoday menu
    Error message
    Error: invalid syntax (<unknown>, line 1)
    Can you send headers?
    [Attachment 77053 - Click to enlarge]
  17. Originally Posted by zxx511 View Post
    Thank you
    Error message
    bad header inputs
    Headers must be enclosed in parentheses {}
    for example
        'Accept': '*/*',
        'Connection': 'keep-alive',
        'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64),
  18. It worked now
    Thank you for this help
    Is there a way to get the download link from crunchyroll?
    Because the mpd link cannot be downloaded
  19. Headers must be enclosed in parentheses {}
    I have a suggestion for you
    Suggest that a check be made to operator input for the inclusion of {}.
    This can be implemented by
    a) if {} is missing the add {} to operator input
    or
    b) you add the {} by default and check if operator has also added it. If yes then delete {} from input
    I think that this would be a great improvement. Error checking is always a good feature.
  20. Originally Posted by zxx511 View Post
    It worked now
    in network tap filter mpd
    1- right click on mpd link copy>copy response
    [Attachment 77059 - Click to enlarge]
    2- open notepad paste>save as> mpd format ( video.mpd )
    3- place the file you saved inside the gui folder
    4- watch the photo for download
    [Attachment 77062 - Click to enlarge]
    or
    that's a great suggestion, thank you very much
  21. Thank you for this assistance
    Everything is working now
  22. Thanks for sharing.
    For channel 4 to work does it require the login info to create the keys.
    If yes where do we input?
    Thanks.
  23. Originally Posted by Spectrumhsm View Post
    Thanks for sharing.
    Thanks.
    So far only no login information, instead use Freevine
  24. Was wondering how to put the payload info in correctly and grab keys. Pssh and lic url=
    AAAATHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAACwiJDcyYzc5ZGZhLTEwOGYtNGFiMS1iNzU2LWM5Y2FhMjFlNmQ3M0jj3JWbBg==
    https://global.corusappservices.com/authorization/widevine/getresourcekey
    token=
      "authorization_token": "eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJzdWlkIjoiNWFlY2I0M2UtYjM0Ni00M2VmLWI3MTItMDA1NTZhZjcyNzFiIiwiZHVpZCI6Ijk1MTkzYjEzLWE3MWMtNDIyOC05ZDdjLWI2N2Q4YWE0YWRmMyIsInB1aWQiOm51bGwsInJlc291cmNlX2lkIjoiNzJjNzlkZmEtMTA4Zi00YWIxLWI3NTYtYzljYWEyMWU2ZDczIiwiZXhwIjoxNzA4NDQ3NDQxfQ.mL56EaxwA_p5Trv22cMSLZbhG_80BBkUaQtlQ_kSsek",
      "license_request_data": [
        8,
        4
  25. Originally Posted by ElwoodBlues View Post
    token=
        8,
        4
    use list challenge tab
    you need this header
        'content-type': 'application/json',
    [Attachment 77148 - Click to enlarge]
  26. Thank you. I get error message. Erorr: Could not parse license_message as a SignedMessage, Error parsing message.
    I just noticed that your pssh is different as well'
  27. Originally Posted by ElwoodBlues View Post
    expired token
    your key
    bebb9c34d192afa589ddda1355d84311:6bba415ea5940cf413ca823d531fe684
    [Attachment 77156 - Click to enlarge]
  28. fresh token did the trick thanks
  29. What data would you enter for base64 payload? Or how would you enter it?
    --data-raw $'\u0008\u0001\u0012\u0082 \u00120\n.\n\u0018\u0012\u0010\u0014\u0019Ö\u0080\u001dÒ\u0011²\u0080T\u0002ARDISHãÜ\u0095\u009b\u0006\u0010\u0001\u001a\u0010\u008d;C{,-6I°\u0089\u001d\u0094¶\u0018¯h\u0018\u0001 Ð×Õ®\u00060\u00168ÐØ\u009dÞ\u000fB°\u001f\n\u0014license.widevine.com\u0012\u0010\u0017\u0005¹\u0017Ì\u0012\u0004\u0086\u008b\u00063:/w*\u008c\u001að\u001c\u0087\u0021©à\u000eþ\u0096Ù;\u008bØ7¯xS)\u0007\u008cH×\u001a«.\u0013Å£·£-\u001d\u0096Pµ±´O\u009b"9\u008bÛ÷É_ð\u0084¾â¿Q`Úº\u008a\u0092*fs\\w$¾\u0098â\u008agÀ\u0012c\u00904\u0008òmÆ~õÏÑ\u001b\u0096\u001cU\u0093\u0098\u009aày\u0001\u0016ï\u0088\u0014cú\u008dºçñ¸\u0089É\u007fó\u008c?e\u0010ñûgüzSyÚ>d7ë\u0006{XÉsú\u0097ô¨sª0å\u0088ôîEBj0Y±\u0008[ð\u000f[hsìx\u0009Q÷6«\u009eäcPïFSa*pfxlHD\u0017\u0085\u0080î¹àD\n\u0007\u007f¦b\u001e\u001aN\u00974(N0¨o\nµªLÁ\u008aË\u008ag\u0082¡\u0018j\u008e\u0090×ãøµÇ¶ÕP_\u0003Ñ=ä\u0010Û\u0000\u000cF¼l8\u0008@\u009dÔµT\u0089d4HÅëý[\u0093â\u0019]R*QgN\u0084|µó8\u001fVHÿ¶B§\'6r\u008d\u0080+f\u000c[øÕ£\u001f/ÿÎ>\u008e±\u008c\u001a£è\u009aÇg®TP|C*:\u008c\u0014æàÕËB\u009a\u0082Î@\u009d\u0095÷\r\u0081}\u0087ïç;¾FOc\u0019ÆmëÚje\u0099\u008e@þ< ÂHä>Ö\u0091H¾(\u0080\u0085\u000e`\u008bâC\u0003\u0009¯ï\u000cC\u0097\u0094ìÕ%æ³e]V)H"\u0081²3\u0009ªl|ê\u0096ù ªPø\u000b\'»y\u0088\u0004îÖnq#\u001dTîÚ{á÷Ê\u001aË\\)\u00180äù¾\u008bvp87n\u009aÜ?\'\u001a¬J\u007f\u0016ßwÚ\u0082\u0001²ãeDÄV`\u0001\u0015Ô\u0013&\'\u0000Ã\u0006\u0012\u000f¼\u009fZëÜÛU\u0015Ò\u0010\u008aÀ¼\u001b8 ?¾Æ*^nÜCý8SÚ\u008eæÛ\u001d%Þðî«/í;*¥æµØ1\u0008ͤ\u00971\u009f\u009d\u0018,\u0090~=pË\u0085üåûAõ¥tÁ\u001e;*ÕÆ\'fè\u0086¡<\u001fÈÙê¿°06`?\u001aä\u0016\u001bU\u0014*S\u0015s#{)\u0017A6?Áv¡ãÐpÉ\u0013O\u0090%mÈ\u0003Ëðë\u0007\roy°7"\u008a\u0097h.\u009e Ô£+º7/^¸é\u0010{·y\nc\u0012wvIê\u009aïû\u0091yøn5z\nÆd+1¤\u0086®)¼Ô\u009d7z\u009e\u0082\u008dö¸\u0081\u0080®>XMV«R[äg÷,¦\u0021J^\u0091l\u0012F\u00997\u0003G®m&Kw>gd®<2\u0017\u0002\u0002\u009e4õ³¯õ\u000213C\u00138¥W\u009d*\u0098\u000b\u001f\u000cmèr*Ã(à\u009bM\u0089\u0007B\u0014Ý\u0005Y\u0013\r\u000bäoÐ\u0005§\u007f85«Z»\'JVhÄÇ\u008fr\u000eR\u0089v\u008cÇ5\u0012\u0002¯\u0018l{û±¼%\u000f\u0084\u001b\u0086\u0010ª\u0014\u0092\u0081xA\u0014PXXLÏUo\u0012hð^}:6»Å1µã\u0015±¼F¡J\u001cü\u009cÑ8\nR\u00192Ïþ7WùA9¸\u0094ÝsA¬5UË;\u0099Øò\u008f×¢=\u0083¸c\u00958Ý%Y\u0089xÿÛ«\u0088\u0088\u0082Ñ\u0088\u001ag<\u0085iÍÓ*ã\u009b\u0087\u0017)\u008cç@±ù=¦aa%{\u001d\u000f²m&¢£ð\u0015\u0099ç\u000e\u0013\u0081e\u001e\r´w}×\u001eÊSþ\u0003ýñb\u0085ñ.Qg>èôcP\u0091µÉ8\u000b|ÒÙ#ÙË\u001d\u008fØ\u0002Vd´\u009bT*%\u0013M_îý*8©\u0085Jrf²rº\u008aÒhI0\u000ehât/\u0001ñ¥°£Ê°òãI24·£Öèd=\u000e\u0018V^(êLi)\u0089Iû\u0018\u0004\u0088îN|F\u0098\u0010*\u0080\u0003\u0015¡í\u009e\u008aR9>KbÕ¶O>JβB\u0093·}¾\u0091%`r)%\u0094\u009f¦\u0088«ó\u0006qMÿµS,²Ûsâó}*\u0081ìÏzÜ\u001b?\u0084ó®Ü\u0087ͼ\u0094\u0000§\u000f{\u0019\u0008\r̳\u0002\u009eÏ(jh\u0008V\u0089¸Ö¥ìÂÙìÞ_D8unvÊ\u0090WæÝ*:2BA¯ÁÌeç\u0083¦ØÏ?\u0008â\u0015\u0086ìHù\u0094Ë\u008e\u0015\u0009¼§\u009c|×a§ð\u009dÒ¥¼ÓU\u001eª\u0017\u009a¯\u0085Pº÷ÀôºÔ}@Ç\u008bÞ5\u009cSÍ»Zx×\u009cq\u009aÿ_-\u001e5çe\r«\u001b@Üá½\u0088ïæ\u000e/µ\u001bÇÇâq\u0080BÇ\u007f\u0019YÕÉ\u0010#ùE\u0003\u009f³7´\u001bc?\u001a\u001c¹T|õtm+\u0085\u0080á¥å\u0091RÚW\u007f\u008a¨\u0015¤´\u0008Hò=\u0098}§\u0004¾´\u00814\u001dÑ-µº²JÎ*Ú\u00835ÓÐò¼[üú+TRv»«\u0097¦Ç}\u009eòaÄ®CKÒñK3Ýô\u001eKt»\u0087G*\u0095ú\n8LGÂ\u0006ßpJ®Àë(_\u009fgK÷±¹\u0084¹¤,MZuc6Ð\u0006ÑL¶Q°\u0001q\u0099x÷Ük\u0011¡=ýç\u0021Y\u001c\u0094Õ;UýVh\u0015«p#\u0021·Y8\u0014g}¦½8\u008c¤´µH\u0015\u0088³Ìü礱*PRï\u0013Ø*\u0087\u001bôõ\u00042-\u009d\u0098Q\u0001êg©QäuêÆ\u009aÙy:8É\u009d\u000bý.®ÃX\u0095\u000c:Ìò\u0093\u008f\u0008#|ÏHÐr\u0094\u008fÑx±õºï3\u0080AkâÆs`x-\u0000w;1g\u0013Rd|\u0014\u0010\u0080à"\u0003Èè\u00080â\u008cÿìë\u008ci*e´ìÍ,\u0097½<ûuRØ\u009cÍ\u0005R\u0019Ñþ\u0087°ïÂäÆ\u0017\u0084§\u001f\\\u0083\u009e\u008eã\u000c:[cTu8Yo7éª\u000b®QHUÈòÙ\u0011õ6\u001aâå_Þë\u0014½\u0008Â\u0012¸ *ç\u0084ð\u0081±ã\u0003\u0014:²YMÖ\u008bméL]¯\u0097a®gg\u009d^á¢%iÆ**Y\u0090ʼ×òQ@\u0019Ô\u0015ÓÐ\u001d(.6¦\u0019_3éôú$åô\u009c\u0091÷\u000cë8\u009d\u0019è\u0000\u001eeó\u0092ð]\u0088\u0004\rt\u008c5à ¿Go_A\u000fN2\u0089\u0097wêF\u0099%\u0012ÌAqåÝæpßDhà¦\u0095*\u0098\u0087á=$\u001aåpÈòRz\u0002yOi`?\u001a§\u0087#¥\u0090ªµ\u0013ͳû5Q³\u0001ºï\rí¾9{H\u0015ôK=§mïÞ+.ÏõÆ\u0018\u0080s¿\u009fAB\u0094\u0002\u0012ßò̬éÜátËgÊþ|ÉÉ\u0092b\u000eÝ8î\u0086Ó¿¹Ñ~É$s\u009f\u0015¾ÉøÚõͺïCEén#²s\\ûàA\u0017{ãh]\u000b#±³Ï*ÕuV\u0014ðváº\u0089´roãIòªpÏ\u001d\u0002Ì÷6Â\u0009TÿõÐ\u009c¨\u0080\u009b_ó¨T\u008b.a\u007fá;s\u0093^³ðÚYAÚÂ}»i®}\u0095Ïr\u009a\u0007w$òp\u0000³±\u008fÓ\u009aD\u0087å^dë\u0087*x\u001f\u009fÔ#¸O\u0081\u009co|®\u0004\u0018·Pâ\u0018t¼ö¯¿tÁïv|L[\u0019¹0\'\u0016\u0090¶ÿýxÙ\u0090pRïnú¬\u0096ÊJ\u008a4pÅ\u0021îrµé§\u0018Y^AE\n*c&}Bôº\u0098*¯\u007f*ò\u0021Ïq\u009d[rÛY\u0003¨+\re\u0018\u001e*vk<}I©wÏ\u0012;c´\u0010wcY3\r\u0084A·\u009dÌÐ\u0004(N\u000fNÂtM)\u0099|Æá¢$-y\u0094}´×Ús\u00945/λ\u0087\u009f\u0014UàÄ\u000bô\u0087NhàŪ\u0008l,Ã\u0001n`\u000bñèI\u0094J\u0017Ø\u0005rÆs\u0095id>±\u0096¯2f¿%Ä\n\u008fÅÆ¯2\u008að`Y\u0004g\u009cÌ#\u001fë\u0090\u0010w\u0092\u0021Þ\u001fÁ¨+\u0005Ú\u0085ãâÄ:\u0015*\u0082iÓ\u009f\u008d©¾ÝtÛä31\u000f²\u00854×\'è@;\u0001\u009c«3\u001cp(ùçibB8O\u0096²ðªÄ&Ó*}ÖàÇê\u0012÷9ay\u0097\r<®\u0003\u0099¬kÿ#¢8Òe=¢Z\u0080´\u008d¯\u000b\u009d¡¹á\u008d.óé«TAÚ¬"Ùh\u009b¢W\u0092\u0003ØV·ÊØnµ\u0087ø®ÇyEc\u0019Âè4±\u000f¦\u009bÊæ\u007fç\u0090\u0014aX¤À%1]ç\u001cãê\u0003$\u001bBÑ´aëÿXÔj\u0097\'G§>qb\u009fX\u0086·×\u001bò¸LÅe\u0017¬\u0004#ß\u009cÑ\u0099\u0083µ\u009a7§è\u0093X¨\u009c¥ò\u0096Yãib\\÷\u0094ì\u001fh¯O[\u0017Õ\u009cp]4E\u0002ÛS\u001fB\u001c\n£ÒÄ\u009c\u0081éÈuìxʾO8\u0093*áu½rÅ@D\u0012*g\u0088*?N#èÊD\u009d¼s§ÇFùJ\u008fOtUfúÔuF%îD±MBÄxgS\'ù¨\u0015D\u0089\u009eá+\u0019\u009a\u0096g¡\u009e>Â\u0000D,\u001f<Þ{\u0012Ü\u0087\u0006\n¡\u0084gÍæÂA.<ú\u0088÷\u0096˸°H\u0011\u001f\u0086Á\u008e¦Ò\u0019\u0084L¾z9ê¢Æ\u0019C\u009d\u009c\u008eçÅ\u000c7{f~Ét2\u0081ÙbãOV\u008d\u009a\u008a\u009a%Â\u009cG\râÓ\u0017A\u0084\u0011\u000e\u0091ð}<QG\u001b×\u000bt0xüEè\n"Z\u0012`V*·\u0092º¿ÂA\u0087ªü;S\u009d£8Ú±\u0011]\u007f\u001fó£p̳Y¾¹cÀÀaÖ¥\u0082AÉåÎ*]\u009cTJ\u0000q\u0006rÃYbwÁåø¼\u008b°\u008b\u007f½x\u0006\u008bí<\u0004Àâê\u000b\nýu-\u009fL\u009cî\u0086iB\u0016`Qô³\u001a\u0090\u001eo\u0086æ£ÆÈ\u008a\rÁ\u009aêZNN\u0000\u0098ÄÏû\u0003ñ+2?)Ð\u0006\u0089Jf\u0086³Øó{+`\u0083Ü\u009fv\u0001A\u009c\u00131~<Í\u00125Ö}¥Ïà0ç{è+¿tÐb\u008d¥£<Y1ö/L#þ\u0007\u0013\u001bÁ>d/uÊ~|ªÿótQ¾\u0017\u001bÁEd\u000bª÷É#·Â\u0016\u0099\u0086é\u001b\u0096·H\u000e\u009bø)$\u000e\u0014¦ÛV\u0010aTÂæ"\u008f\u0015L¹\u009eðTpâ`v¯\u0015ÄÁSý\u000b\u0018W(É\u0080ò°u?ÛZ.¨¦t_:qc\u0091É^\u009ew\u009døv7jè\u007fþòHïò\u0002ÃETOöà¶B\u0091DïT\u0016òe\u001d\u001b%j:.\u0016rÕ\u000f\u009d\u0016¼¨UºãÁ½\u0086\u0013\u0080\u008c\u0017\u007fReHd\u001e\u000f\u0089\u009aê.µÅ)\u000bÐB"¿Àf\u001e)\u0018°\u0004Á^ó§fÓ\u0093\u0018VÙ\u0016\u0019\\\u0093W\u001b\u0003\\yø\u0010âT±¦Á\u0006zEý)ìK\u0001Úì\u001c\u001b\u0097Ⱦu¨õ\u0094Ïr\u0010{\u0082~§GW¢_üö\u0099³48\u0097·÷ÏKA§Í\u0088\u0006TÚ~\u0008\u0002\u001eUäÉ>\u009d<º:Uµ\u0006@tÌ\u008e\u008f_ËÑ\u0010gpQ\u009b\u0089FÉÌ\u0093Ñb62[\u001a/Ó %Ô\u00150\u008f¥\u0097\u001bÜE\u0000Ø¿\u008dX\u0099\u008c×}|\u0092ͯh\u001d\u008eYx\u000fÙÃj\u000e\r\n\u008eq\u0095wü;À9Kn\u0011ÖuöɰÄ\u001cA\u0081È\u000ch\u009aí\u0009J\u001c\u009eA~zÎÀ¾V\u0016ËyÉ\'\u000e>õ\u0099\u000c[j\u0005\u001cÇ\\¢\u001fí\u0081Ï Ã\u001c\u0086\u0017\u007fr\u009aÿ´ºÄÈ\u0091Á\'´»½CXkØí\u000c=\u0014SÿÑ7£-ÙlìùE$\u0010Ho÷\u001aÌNÃmòh]\u0098Ý\u0094ü~\u009aÜ\u0017*\u0091R\u0085zæe+\u000bµpÁg{áÞñ\u0090Lɤ)iu\u000c_ÎFM0ü\u0083Û®\u0091Î\u008cHx¶í\u0086QC*û\u0088ß\u001bÍHÔ¿-¨\u0013\u008fD0Ûô\u0009¨N§8í\rÁ\'\u0001{Ä\u001b\u001c4~Íã{9\u0016\u0001ãÐ%*\u0095k\u0001¢å\u009fÉ\u0006\u000cQF=\u0089T«\u0001\u0093§\u001dx\u0004Ì+v\u001cȺr×aD&ûîT¹Ð"ã\u000fàûäQ§£\u0081\u0021\u008cʹ¥û]hO7i\u0091å\u000c÷\u009bìAa\u0087\u0014Ng0\u0017#0SF3}\u0009\u0010\u0089a³kg0\u001ec\u009a`x\u0082\u0099çbÊW\u0092e\u001bMeÅð,Øq\u0009ÐPí»ø\u0088\u0086mýñ\u008aöA{\u0004VÿVL\u00101B,20Ê\u0094Yõ\u0082Ô4\u008e=Q2ân\u008fn\u0002\u0007Â\u0098£J\u0019\u0017\u0088§öM\u001dBüå\u008fJÏR§\u0004;µ\u0013¯¶¬è@¢\u0082òzI*\u0098\u0082ÂØéB6\u0082 \u0093@ÄtQ\u0008\u0016g\u0093ö"×\u0002 HÐi¼·²ó¥T\u0090\u0005AñC|BÔ\u000e×f\u0011þf»Ä]Sì¹\u0014\u000b\u008b\u009f_6D·\u00060\u0084Pð\u0082¿ë§<ï\u008bpXôHW\u009fuL\u0088qi\u001a¼*ûvæv\u0013®^ûÜ.|G)øç\u0007\u0087oS¨*[&;¶Á$o9`\u0003\u009bï\\\u001d×¼Ü\u000bðätþ¼Â²ÿâ\u009dàB\u009d¨M²0æi\u0021\u0083y\'ç£K\u001c\\w/&\u009b\u0010r\u0019\\\n¼D£\u0012È\u0008\u009fJçËÿúÐ8\n?\u0087ëÜõé£Ó²BÈQ\'P\u001eßâ\u0008T¥\u008eߦê\u0096\u0000\u0080é3Ý\u008bÊLQ}@&Â;h0"\u001f¯â-¯\u001e_byü\u0008Î\u0000\u009e\u001d\u0008É\u0082\u0089-¨\u009d\u007fÐË\n¯$ÀþMÅ:}¬¢\u0081+íoó÷A$\u008cÊ/0\nc\u0018\u0008\u0006j1§í54û\u001eÔ\u0003b\u008aÉ*\u000fÆÐð{ ï\u0086T×:=\u000c\u0013\u0093ka\u008c*t£2ôTý"«ä;åÙ\u0080ó1\u0082Þâ¸"\u0010\u00860u\u008fxR\u000b\u0091N²{v.\u0080\u0015\u009f*\u0080\u0002\u0093/\u0002\u007f׬£Þõ½\rB w«Ëæ¥û\u0098`°[Ðë²¶&V\u001e½$.Ffú;\u0001ôî+\u008cË9uÜ®\u0015\u0013cjyW¿Á\u0082\u0009ÛZÙ1z¨Js\u0088~í1\u0018\u001eß\u0086\n9uÝx¥á\u0083¼W-\u0010Gý´Ûø&°NUÀ%ü\u001e\u0012÷×ý\u0014õHÅ\u008c\u00894\u009f±\u0004ßâÉ\u001e\u0021\u009bq\u00064TIb\u0007\u000cëw²}ËoÔ\'ïFõV\u009cµ\u008ci\u008d"\u0003*\u0090\u0089:quûT;}*\u001du1\u0011#3ñ\u0082\u0084øÔ¬\u009ej\u0088êJ\u0003(á\u0005\u001e\u0095Ø\u0085\u001a.\u0083ñ«\u008fìãÇá#ê:JJ\u008eQ\u001e¤mz©Á\u0085s\u0004\u000fèlÐÖ\u0001Ï4\u009a*O®Y¼;´°¿ùÍúÚ¢Ã:Èú7f67\u0082\u0006"§=`BáÄ\u000e\u0093?6·\u009dסJ\u000b4.10.2710.0\u001a\u0080\u0001o7q¾eîfYþ\u0003V\u0093´z\u0010u*8\u000cÌ~}µu5öî2üß\u009f<\rx\u0084¯Ö\u0005F÷\u0095\u0082>Ñ4\u001e*Âä©«Ü\u0093Åß]\u001a\u0015pW¡¬¦/\u0000GÚä$¬ ¨\u0008xFé5¼\u0012\u000c\u0089q\u0003?\u009e\\\u0098û\u0018yP»§*:_×ej\u008eZå|צ\u00017h\u007f\u0089ôpÿ;\u008b\u0012®ÊC¿\u0090\u0018ÉÔl\u0019²\u0021J\u0014\u0000\u0000\u0000\u0001\u0000\u0000\u0000\u0014\u0000\u0005\u0000\u0010ûÇlP#\u001c\u0015À' \
      --compressed
