Hi am I doing this right.
I'm using xmediarecode. I want a single pass with very good quality and I don't care if it gives me a high file size.
I use fixed quantizer with a low value. The one I'm using now is 2.
I'm assuming it gives me very hight quality...does it just make all the frames the same bit rate?
No. The bitrate will vary depending on the amount of noise, detail, motion, change of brightness, etc.
splotched interlacing. What happened here? Can it be fixed?
By LaserBones in forum Newbie / General discussionsReplies: 8Last Post: 26th Aug 2023, 17:20 -
ffmpeg non linear quantizer
By dannyboy48888 in forum Authoring (DVD)Replies: 12Last Post: 8th Aug 2023, 16:43 -
Audio help please can this be fixed
By victoriabears in forum AudioReplies: 11Last Post: 28th May 2022, 19:14 -
windevine in chrome 89 is fixed ...
By ram456 in forum Video Streaming DownloadingReplies: 9Last Post: 29th Apr 2021, 09:46 -
compiling with fixed options ?
By netlink1987 in forum ProgrammingReplies: 6Last Post: 9th Mar 2020, 22:44
