I have build ffmpeg v6.0 for my server ubuntu 22.04 LTS with the gpu tesla t4, but the binary ffmpeg cannot found the filter overlay_cuda. It's normal to use nvenc encodec and cuvid decodec.
Run the command:
it outputs error message:Code:ffmpeg -h -filter=overlay_cuda
Here is my compile ffmpeg configure:Code:Unknown filter 'overlay_cuda'.
I wonder there are any options about cuda filter missing?Code:PKG_CONFIG_PATH="/usr/local/lib/pkgconfig" \ ./configure \ --enable-cuda \ --enable-cuvid \ --enable-nvdec \ --enable-nvenc \ --enable-nonfree \ --enable-libnpp \ --nvcc='/usr/local/cuda/bin/nvcc' \ --extra-cflags='-I/usr/local/cuda/include' \ --extra-ldflags='-L/usr/local/cuda/lib64' \ --enable-opencl \ --enable-shared \ --enable-gpl \ --enable-nonfree
Additionally, my nvidia driver is 525.147.05, cuda tool kit verison is 12.0, and the nv-codec-headers is release sdk/12.0.
Not sure whether it helps, but:
a.
returns:Code:ffmpeg.exe --help filter=overlay_cuda
with my builds from using https://github.com/m-ab-s/media-autobuild_suite for Windows so looking at how they build stuff might help.Code:Filter overlay_cuda Overlay one video on top of another using CUDA Inputs: #0: main (video) #1: overlay (video) Outputs: #0: default (video) overlay_cuda AVOptions: x <string> ..FV....... set the x expression of overlay (default "0") y <string> ..FV....... set the y expression of overlay (default "0") eof_action <int> ..FV....... Action to take when encountering EOF from secondary input (from 0 to 2) (default repeat) repeat 0 ..FV....... Repeat the previous frame. endall 1 ..FV....... End both streams. pass 2 ..FV....... Pass through the main input. eval <int> ..FV....... specify when to evaluate expressions (from 0 to 1) (default frame) init 0 ..FV....... eval expressions once during initialization frame 1 ..FV....... eval expressions per-frame shortest <boolean> ..FV....... force termination when the shortest input terminates (default false) repeatlast <boolean> ..FV....... repeat overlay of the last overlay frame (default true) framesync AVOptions: eof_action <int> ..FV....... Action to take when encountering EOF from secondary input (from 0 to 2) (default repeat) repeat 0 ..FV....... Repeat the previous frame. endall 1 ..FV....... End both streams. pass 2 ..FV....... Pass through the main input. shortest <boolean> ..FV....... force termination when the shortest input terminates (default false) repeatlast <boolean> ..FV....... extend last frame of secondary streams beyond EOF (default true) ts_sync_mode <int> ..FV....... How strictly to sync streams based on secondary input timestamps (from 0 to 1) (default default) default 0 ..FV....... Frame from secondary input with the nearest lower or equal timestamp to the primary input frame nearest 1 ..FV....... Frame from secondary input with the absolute nearest timestamp to the primary input frame
and
2. The call also works with the builds I compile for Hybrid on Ubuntu 22.04 using https://github.com/Selur/HybridDeploy/blob/master/build-tools.sh
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
Rescaling the Tinterlace filter outupt in FFMPEG
By JackyBorderCollie in forum Video ConversionReplies: 2Last Post: 4th May 2023, 15:40 -
how to compile and run ffmpeg for 64 bit Linux?
By oduodui in forum LinuxReplies: 4Last Post: 6th Apr 2022, 04:13 -
how do i add libx264 and hevc to ffmpeg when i compile ffmpeg for ubuntu 21
By oduodui in forum Newbie / General discussionsReplies: 2Last Post: 17th Jul 2021, 05:12 -
how to compile ffmpeg for arm64 for huawei p30lite
By oduodui in forum LinuxReplies: 3Last Post: 30th Oct 2020, 09:44 -
Handbrake\ffmpeg blur-and-warm filter?
By andy_larkin in forum DVD RippingReplies: 0Last Post: 29th Apr 2020, 23:25
