I have a MP4 video file thats 9gb that i want to burn to DVD with a menu using DVDstyler, Now, if i choose the DVD-9 option in DVDstyler the resulting file size to be burned is around 5gb.
I would like to keep the 9gb mp4 quality.
So,am i loosing 4gb of video quality once burned to DVD?
Can i fill the DVD-9 to its 8.5gb capacity (with a bit of compression)?
Results 1 to 12 of 12
Working in a different order,
Yes, you can (and probably SHOULD) use ~up to the full capacity of the disc. That gives you the best quality for the running time.
Mp4 files could be ANYTHING, including HD/UHD material, so there is loss there.
ANYTIME you reencode using a lossy codec you are losing quality, regardless of the bitrate. So raising the bitrate will alleviate that loss, but some will still be there.
The fact that is being encoded to Mpeg2 (which DVD Video requires) means it isn't going to be nearly as efficient as the source files (which are likely AVCinMp4), so the loss in quality will be more noticeable.
Depending on what player you have and whether it supports playing raw mp4 data files, you might want to consider not converting your files at all, but just burning them as-is onto a standard DVD data disc.
Scott -
See the Technical Info at
https://www.videohelp.com/dvd
You'll see the video bitrate maxes out at about 9mbps as per the DVD spec.
This is where your inability to fill the DVD-9 come into play -
@davenext is correct. For just 1 file that is 87minutes, at 9.8Mbps that works out to ~6.3GB as the max that it can use.
Scott -
Ok, thank you all very much for your help, much appreciated, thanks again.
Staxrip deinterlace - extreme file sizes
By Traderbam in forum Video ConversionReplies: 16Last Post: 1st Aug 2023, 10:33 -
Editing video - file sizes are too big?
By jrodefeld in forum Video ConversionReplies: 2Last Post: 25th Oct 2022, 13:29 -
Consistent decimal display for file sizes on Windows
By Sapito in forum ComputerReplies: 1Last Post: 9th Jun 2022, 21:01 -
Toast giving inaccurate file sizes
By Kal-El in forum MacReplies: 0Last Post: 10th Oct 2020, 14:08 -
Manageable File Sizes for Editing
By teddybouch in forum Video ConversionReplies: 5Last Post: 27th May 2020, 10:01
