I own a Toshiba SD5109 progressive DVD player. It was a fairly expensive player in its day and I thing highly of it and have no desire to get rid of it (if you have ever seen a progressive DVD play on a digital TV at 480p then you understand).
But this SD5109 is useless for playing anything recordable... be it CD-R or CD-RW (I can get a VCD to at least recognize but play real jerky on some brands of CD-RW). I also read on many forums/sites that DVD-R does NOT play on the SD5109 either (this of course did not surprise me).
I read on www.dvdplusrw.org that the SD 5109 did in fact work with both DVD+RW/+R but I learn to believe it when I see it.
I bought the HP dvd200i yesterday and burned my first DVD Video using the included Sonic MyDVD. I tried it in the SD5109 and it came up with Disc Error. So then I used the included HP compatibility tool and changed the +RW to mode2 and voila... works no problem. Next I tried a DVD+R and it also worked in the Toshiba SD5109!
Now what is my point you ask? Well I am not implying that DVD+RW/+R is superior to DVD-R/-RW (I am not qualified to make that assumption, nor do I have experience) but it seems possible that DVD+R works in some drives that DVD-R doesn't and vice-versa. It could be possible for a biased reviewer to stack the selection of drives in favor of the particular DVD-recordable format he/she prefers!
I could be wrong on the SD5109 and DVD-R compatibilty - someone please correct me if it DVD-R does in fact work. I base my information that it does not work when I was researching to buy a Pioneer A03 last year - I had read many reports that it did not so that was enough excuse for me not to get into DVD recording at that time.
Results 1 to 14 of 14
I would expect that some machines that do not support DVD-R will support DVD+R, but I also think that slightly more will support DVD-R.
As for your Toshiba, DVD-R is supported. See here. DVD-RW is not however, and maybe that's where the confusion came from. -
Eug, thank you for showing me that DVD-R works on my Toshiba SD5109. It is good to know this. Maybe I shoulda researched more current news before posting - was just excited about something working in my SD5109!
I notice that it is reported that maybe some brands of DVD-R may not be as good as others... could be same situation for DVD+RW/+R too!
What was the other format called that preceded DVD-R general format? It was a professional format and the recorder was $4000+ - maybe that is what I read did not work in my SD5109.
From what I read and understand, DVD+RW is more compatible than the DVD-RW counterpart, but in the future most new consumer DVD players should support DVD-RW playback. -
DVD Authoring disc. I've never used one, but if the disc has been authored correctly then it should still have worked from what I've been told. Not guaranteed though, and it may have been a specific dye type that your player doesn't like. Try a high quality general use disc (eg. Apple brand general use disc) recorded in a Pioneer A04 or something before you make a final conclusion.Originally Posted by HeeD
From what I've read DVD+RW is NOT more compatible than DVD-RW. They're about the same. DVD+R and DVD-R both are much better than DVD+RW and DVD-RW for compatibility. Whether DVD+R is as good as DVD-R remains to be seen - hard to know since it just came out.
Check my sig for more info. -
Don't get caught in the hype that is presented at dvdplusrw.org (like the following incorrect statement posted above). dvdplusrw.org offers very dodgy information on both DVD recording formats. I really recommend checking out the highly detailed and unbiased DVD FAQ at DVD Demystified. The link is here -- http://www.dvddemystified.com/dvdfaq.htmlOriginally Posted by HeeD
That FAQ should answer most, if not all, your questions.
Kusanagi -
Kusanagi,
That statement you quote me as incorrect is my own opinion and it is not a direct quote that from www.dvdplusrw.org, although it may sound like something you read there maybe! Note I was comparing it to DVD-RW and not to DVD-R. I have read much lately that DVD-RW is not nearly as compatible as DVD-R so I presume that DVD+RW would sit somewhere in between and therefore be more compatible than DVD-RW, but less compatible than DVD-R.
That FAQ site you gave me actually tells me to go www.dvdplusrw.org for more information on DVD+RW - go figure eh!
Who knows what DVD+R will be, but all I know is I submitted an e-mail to the person maintaining the compatibilty list found at www.dvdplusrw.org to add the Toshiba SD 5109 and he added it within a day. From my brief experience they seem to be an ok site so far.
I understand that the entire DVD+RW media was supposed to offer superior compatibility and reliability than DVD-R, but it was a letdown and found to be not as compatible... maybe that is why MS likes em - they are on the same wave-length
If you check VCDHELP.COM you'll see that DVD+RW and DVD-RW compatibility is similar. ie. not that great.Originally Posted by HeeD
Hm. You seem to have been doing this for some time deliberately to hurt the credibility and reputation of DVDplusRW.org and its forum.Originally Posted by Kusanagi
I have no clue what u are talking about?Originally Posted by Kennyshin
It is a fact (as supported by many members and mods here) that your DVDplusRW.org does not offer honest information and is always subjective to DVD+RW.
I would not be surprised to find out that DVDplusRW.org is actually run and funded by the +RW alliance.
Kusanagi -
http://www.dvdplusrw.org/cgi/ikonboard/topic.cgi?forum=3&topic=56&start=0Originally Posted by Kusanagi
http://www.dvdplusrw.org/cgi/ikonboard/topic.cgi?forum=3&topic=56&start=10
http://www.dvdplusrw.org/cgi/ikonboard/topic.cgi?forum=3&topic=56&start=20
http://www.dvdplusrw.org/cgi/ikonboard/topic.cgi?forum=3&topic=56&start=30
http://www.dvdplusrw.org/cgi/ikonboard/topic.cgi?forum=3&topic=56&start=40
Who has set up this website? -
Please stop Kenny, it is beyond annoying now. Links to just DVDplusRW.org make your rebuttals even less credible.
And stop bumping old threads just to promote your DVDplusRW.org cause.
Kusanagi -
Wasn't it you who first invited me to these threads? That very threads accusing DVDplusRW.org of banning DVD-RW people? The truth is just there for all the world to see.Originally Posted by Kusanagi
Still no?I have no clue what u are talking about? -
God no. You came in here and blasted everyone with your high-res photos and DVDPlusRW.org links everywhere.Wasn't it you who first invited me to these threads?
I think most VCDHelp members and those intellectual lurkers know the truth since DVDplusRW.org has been exposed for its false information and slanted/bias advice.The truth is just there for all the world to see.
Wha? Sure, no it is.Still no?
You contine to insist on fighting when there is nothing to even fight about. Again, get off it and relax.
I've had enough of this DVDplusRW.org and its propaganda now. I'm done commenting on it.
Kusanagi -
Ragging and saying how bad dvdplusrw.org's site misleads information doesn't really prove that DVD-R is superior to DVD+R. What we really need is RELIABLE REVIEWS that show which format is more compatible than the other . Also, whether one is "the industry standard" doesn't automatically prove one format is compatible than the other, and can also go the same with with Mt. Rainer support from Microsoft. What we need is thorough head to head tests. I have one here from zdnet, which I doubt whoever wrote the article is a "+RW propagandist"...
http://www.zdnet.com/products/stories/reviews/0,4161,2868531,00.html
To sum it up, we need more time. All this DVD+R and DVD-R bashing is useless and doesn't prove anything. Dvdplusrw.org may have some misleading information (basically how the first generation drives can't burn +R) but all the bashers don't really see all the SUCCESS stories from that site. Just ask Eug he posts there all the time and he owns a DVD-R drive. He brings out the best of DVD+R because he points all the weaknesses and strengths it possess and is open to new formats.
So, basically stop the FLAME WARS!
8)
Samsung BD-P3600 DVD+R compatibility
By ynoldus in forum DVD & Blu-ray PlayersReplies: 5Last Post: 14th Oct 2009, 15:55 -
DVD burner compatibility with Dell
By LWC in forum ComputerReplies: 14Last Post: 29th Nov 2008, 09:17 -
Check for DVD-compatibility
By otternase in forum Video ConversionReplies: 1Last Post: 29th Aug 2008, 04:58 -
dvd player with the best compatibility?
By JCWagener in forum DVD & Blu-ray PlayersReplies: 23Last Post: 16th Nov 2007, 22:17 -
Increasing DVD playback compatibility
By Truelight54 in forum Authoring (DVD)Replies: 1Last Post: 15th Oct 2007, 18:51
