I tried compressing jp2 and j2k files into a pdf file in Adobe Acrobat, but it won't work. How do I fix that? Also, when compressing BMP and PCX to PDF on it, does it convert them to other formats before compressing it?
[Attachment 76780 - Click to enlarge]
For ffmpeg jpeg2000 , you need -format j2k to make it compatible for Adobe . Adobe's jpeg2000 encoder offers higher compression than ffmpeg's jpeg2000 encoder , but filesizes will be smaller if you use j2k or jpf outside of the PDF, because PDF container adds overhead
But if you're using lossless 8bit RGB input, you can use PNG and it will produce the same results, if you use the same settings for the output
It depends on the settings used in Acrobat. By default it will be jpeg lossy (medium), you can change it . Lossy jpeg is usually the default for everythingAlso, when compressing BMP and PCX to PDF on it, does it convert them to other formats before compressing it?
JPEG2000 Problems
By Mr. Fanservice in forum Newbie / General discussionsReplies: 21Last Post: 5th Feb 2024, 13:43 -
pdf file help
By anandgpt75 in forum User guidesReplies: 3Last Post: 30th Dec 2023, 10:06 -
How do I find this PDF in inspect?
By Bekkeh in forum ComputerReplies: 6Last Post: 18th Nov 2023, 04:15 -
Help converting jpeg2000 dcp mxf files to y4m
By sophisticles in forum Video ConversionReplies: 1Last Post: 28th Dec 2022, 16:24 -
Is any one able to playback JPEG2000 smoothly?
By sophisticles in forum Newbie / General discussionsReplies: 0Last Post: 26th Dec 2020, 14:01
