  1. Do BMP and TIFF support YUV?
    Also, in ffmpeg, what the command line for getting information on an encoder or codec? When I use it and Shutter Encoder make png files, they are 48bit instead of 24bit. How do I fix that?
  2. Originally Posted by Mr. Fanservice View Post
    BMP does not , TIFF support some YUV pixel types
    ffmpeg -h encoder=blah
    where "blah" is the encoder . It will also tell you want pixel types are supported
    Not sure about shutter encoder, but in ffmpeg you can use -vf format=rgb24 . If you're converting from YUV video, you might want to control the YUV to RGB conversion with zscale ,otherwise you might get the wrong conversion, wrong colors. There are some previous threads on this with examples, use search
  3. Originally Posted by poisondeathray View Post
    Does TIFF support YUV 4:2:0, 4:2:2, and 4:4:4?
  4. Originally Posted by Mr. Fanservice View Post
    You can check it yourself . 8bit YUV 420,422,444 are supported - these are yuv420p, yuv422p, yuv444p . The "p" stands for planar
    ffmpeg -h encoder=tiff
    Encoder tiff [TIFF image]:
    General capabilities: dr1 threads
    Threading capabilities: frame
    Supported pixel formats: rgb24 rgb48le pal8 rgba rgba64le gray ya8 gray16le ya16le monob monow yuv420p yuv422p yuv440p yuv444p yuv410p yuv411p
    TIFF encoder AVOptions:
    -dpi <int> E..V....... set the image resolution (in dpi) (from 1 to 65536) (default 72)
    -compression_algo <int> E..V....... (from 1 to 32946) (default packbits)
    packbits 32773 E..V.......
    raw 1 E..V.......
    lzw 5 E..V.......
    deflate 32946 E..V.......
  5. Originally Posted by poisondeathray View Post
    raw 1 E..V.......
    lzw 5 E..V.......
    It doesn't support 10bit YUV?
  6. Originally Posted by Mr. Fanservice View Post
    10bit YUV is not on the list for ffmpeg TIFF support . 10bit420 would look like "yuv420p10le" in the supported pixel format list
    Maybe other non ffmpeg TIFF implementations support it , not sure
  7. Originally Posted by poisondeathray View Post
    Like what?
