hi there,
i want to download this trailer from this site, the trailer is free ..
https://www.wingfox.com/c/8598_340_12663
the video link is like this but can not download it ..
https://hls.videocc.net/9215d65496/0/9215d6549696c666a3b25993db41cc60_1.pdx?pid=170690...device=desktop
So, even if you get the key and the encrypted fragments, you still can't get the video. You can try decrypting the fragments and vlc detects a proper video, proper duration, proper codec etc. but it can't play it. Apparently, the site has its own built-in decoder. That is 100% true for the video part. I dunno if it applies to audio as well (was too lazy to check). The audio was easy to download by simply injecting some js code into a function that deals with the final audio fragment. You can get the audio part here (rename it to ts extension after download): https://www.transfernow.net/dl/20240203cR2TGnif
The video part is kinda tricky since it deals in the end with some yuv frames. I don't even know what are those. Maybe they can be exported. Needs some research.
Edit: Seems I was right.
[Attachment 76755 - Click to enlarge]
I need to code a way in which I can get all the frames now. I dunno if this is lossless though since I convert from yuv to mp4 through reencoding I guess.
Edit2: It is kinda working but just barely. There is a drawFrame function which handles all yuv frames. However it is in no way a viable solution, since this is just a 1 minute video. The alternative would be to understand their built-in decoder.Last edited by 2nHxWW6GkN1l916N3ayz8HQoi; 3rd Feb 2024 at 14:50.
Downloading from Streaming plus
By xxxxxchanchu in forum Video Streaming DownloadingReplies: 5Last Post: 25th Nov 2023, 13:22 -
Help with decryption and downloading streaming video
By dukgosan in forum Video Streaming DownloadingReplies: 5Last Post: 12th Aug 2023, 08:08 -
Video Streaming Downloading Forum
By A_n_g_e_l_a in forum FeedbackReplies: 4Last Post: 15th Feb 2023, 11:40 -
How can i Download Video Streaming Downloading?
By devidwins in forum Video Streaming DownloadingReplies: 3Last Post: 5th Jan 2023, 03:42 -
Downloading Streaming Videos?
By MadMaxnightRider in forum Video Streaming DownloadingReplies: 3Last Post: 7th Feb 2020, 23:33
