When I use mkvtoolnix GUI the subtitles are not on the new file. I have updated the MKVTOOLNIX. Also, the subtitles are embedded in the file. This has never happened before.
Usually, I will select English, then default-no.
How do I fix ths?
I think the subtitles are correctly being muxed in the mkv. And I here wonder if OP would mean that a player doesn't show them, also because of
In which case it may help to instead mux the subtitles with Default set to "yes". If that wouldn't help, player's settings of "default subtitle language" and/or even "GUI language" can dictate to not show them. Using the remote's subtitle button, or - when on pc - in player's GUI manually selecting the subtitles, then will help. -
Make sure the sub is both 'enabled' and made 'default'. Open the header editor and check. Also a simple check use MediaInfo for the presence of an independent subtitle.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
The only options I have for this are default track and track enabled. They are listed under subtitle track 3. I changed the new value to yes, but there were no subtitles after the mux.
Can't get MKVToolNix GUI to make chapters.
By EnterSandman in forum Video ConversionReplies: 2Last Post: 3rd Jun 2023, 08:18 -
Virtual timeline in MKVToolNix GUI
By stirzor in forum EditingReplies: 0Last Post: 3rd Jul 2022, 08:21 -
GUI versions inside MKVToolNix
By carlmart in forum Video ConversionReplies: 9Last Post: 30th Aug 2020, 10:36 -
MKVToolnix-GUI 37.0.0 x64 not running/only taskbar icon
By zombiovsky in forum Video ConversionReplies: 1Last Post: 1st Oct 2019, 16:07 -
Edit Meta Data, MKVToolNix GUI, Commands?
By Alieo in forum Blu-ray RippingReplies: 1Last Post: 23rd Mar 2019, 15:13
