Hello,
I recorded a MKV file with 2 audio streams and 1 video stream using OBS Studio. (Those better in the know than me might say it was a poor choice to use OBS Studio for recording this but it was the easiest app I could setup to record both headset microphone and incoming audio on speakers.)
The file is an MKV, ~4 GB big, and ~4 hours long.
Using the audio quality set correctly usually the file size is around 3-400 MB.
The audio quality is set to 1000 kbps CBR (IIRC) or something ridiculously high, otherwise normal audio.
The video is intentionally set to just a small black screen (~240x180, lowest FPS possible).
Questions
1) Is there a better free/open source app to collect microphone and speaker output? Either on Windows or Linux?
Why: OBS Studio worked, whereas Audacity and Goldwave the settings to use were not clear and I couldn't get it to record both audio streams through trial and error.
2) Are there particular settings I should use when downsizing?
Why: I've tried to do audio 'downsizing' many years earlier in Audacity from a 2 GB wav to a smaller mp3 and the audio became very robotic even at 320 bit rate, I fiddled with settings and got it acceptable but not enough so that I'd delete the 2 GB file.
Is there an App can batch mux mp4 and srt files into MKV on MacOS?
By shruru in forum MacReplies: 4Last Post: 21st Jun 2023, 17:48 -
What app can I use to tell me if an .mkv movie is x264 or x265?
By HartsVideo in forum Newbie / General discussionsReplies: 25Last Post: 19th Oct 2022, 08:17 -
How can I compress audio using the same settings of the original one?
By Clever Sleazoid in forum AudioReplies: 15Last Post: 15th Oct 2021, 06:16 -
Empty audio from MKV file
By ZetaStax in forum AudioReplies: 2Last Post: 2nd Aug 2019, 04:51 -
How to extract audio track of .avi file to include it in a .mkv file?
By nickiman in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2019, 07:15
