Results 1 to 17 of 17
    Feb 2024
    West Midlands
    I'm looking for a video/screenshot guide of how to capture and download content from ITVX and UKTV Play. I've been trying to read various comments on the forums page but not getting anywhere with Terminal on MacOS as most screenshots I have seen are for Windows. I have yt-dlp installed too.
  2. N_m3u8DL-RE is also available for macOS
    Feb 2024
    West Midlands
    Thank you. I can get the mpd link for a UKTV Play video as I have an extension for it on Chrome to capture it. Will it work by adding the link into N_m3u8DL-RE? Can PM me details if that's better?
    Feb 2024
    West Midlands
    I have the manifest.mpd file but there's lots of pssh codes? How do I set this up on https://keysdb.net/ to get the key?
    Feb 2024
    West Midlands
    Originally Posted by cedric8528 View Post
    I now have the key but how do I use it with the .mpd file?
    Feb 2024
    West Midlands
    Also how do I install N_m3u8DL-RE within Terminal?
    I get in Terminal: /Downloads/N_m3u8DL-RE: Permission denied
    Feb 2024
    West Midlands
    This is what I type into Terminal:
    N_m3u8DL-RE "https://manifest.prod.boltdns.net/manifest/v1/dash/live-baseurl/bccenc/1242911124001/1e313ec7-bcd6-453b-a33e-f4a6d2b1c3d2/6s/manifest.mpd?fastly_token=NjVlMjBkOTNfOWEwMjMzNjBi MTllM2UzYmIxMGQwYmJkMDBmMWI1MDQ1NDVmZjBjNDIxMmI5YW Y3OWUxMWM1MjlkMGYyYTJjMg%3D%3D" --save-name _TEST --key a4d12f0238dc48ec8ab7bb4fba88ebea:61719210ebb049ce6 3a2886049432c9e -mt -M mp4 -sv best -sa best
    I get back:
    -bash: N_m3u8DL-RE: command not found
    Feb 2024
    West Midlands
    I'm now getting:
    ERROR: mp4decrypt not found!
    Dec 2021
    england
    https://www.bento4.com/downloads/
    just get mp4decrypt only
    Feb 2024
    West Midlands
    I’ve downloaded it but where is the mp4 decrypt file located?
    Dec 2021
    england
    i dont have mac os
    Feb 2024
    West Midlands
    Can anyone help with MacOS?
  13. Originally Posted by gwilliams1996 View Post
    Put it in the same folder where you put N_m3u8DL-RE (unpack it of course if it's zipped).
    Feb 2024
    West Midlands
    Got it working now, thanks for your help.
  15. Originally Posted by gwilliams1996 View Post
    Can you make et step by step brother? I have Mac to
  16. Member aqzs's Avatar
    Mar 2024
    Paris
    Download and place N_m3u8DL-RE in a folder that will not move and copy the path.
    In your terminal type :
    nano ~/.bash_profile
    Then add this line :
    alias N_m3u8DL-RE="PATH"
    For exemple mine is :
    alias N_m3u8DL-RE="/Users/user/Documents/GitHub/DRM-remover/TOOLS/N_m3u8DL-RE/N_m3u8DL-RE"
    Then ctrl + x then y then enter. Then type :
    source ~/.bash_profile
    For mp4decrypt install bento4 with homebrew :
    If you don't have homebrew (https://brew.sh/) :
    /bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
    brew install bento4
