Hello
I was hoping to find someone on here who may know of a way to clean up this very old video footage.
It's a PAL 25 frame, 8mm video https://drive.google.com/file/d/1rIWZB-Yylb4mlb0nAD5k12eVB63YE_SN/view?usp=sharing, which was converted by a professional many years ago (no longer have the original film). Unfortunately, I only use windows 7 and Avisynth 2.6.
I really didn't want to apply too many filters as it looks as though not much can be done. So far, the script I have used is the following:
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\ChromaShift.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\DGDecode.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\DeGrainMedian.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\deblock.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\TDeint.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\SmoothUV.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\Denoise.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\masktools2.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\aWarpsharpMT.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\despot.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\MipSmooth.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\MosquitoNR.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\Deen.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\unblend.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\RemoveDirt.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\Decomb.dll")
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\UnsharpHQmod.dll")
directshowsource("F:\1970's - Footy Scrapbook Compilation\8mm Film.mp4")
Import("C:\Program Files (x86)\AviSynth\plugins\QTGMC.avsi")
ConvertToYV12()
Tweak(bright=0.00, sat=1.30, cont=1.00, hue=-0.00)
aWarpSharp2(thresh=200, blur=2, type=0, depth=16, chroma=4)
UnsharpHQ(THRESHOLD=5, SHARPSTR=10.0, SMOOTH=0.5, SHOW=false, MODE=0, OPT=0)
AssumeTFF()
Any help would be greatly appreciated![]()
Sorry, to say this, but just looking at the encoding settings:
Code:Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=4 / lookahead_threads=4 / sliced_threads=1 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=abr / mbtree=0 / bitrate=4000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
From my perspective looking at the provided video, aside from deblocking there isn't realy antyhing worth to save.users currently on my ignore list: deadrats, Stears555, marcorocchini -
Selur is right.
However, johnmeyer will give you the right indications; in the meantime you can read https://forum.doom9.org/showthread.php?t=161493 -
The link lollo provided will show you how to get rid of the blends but, unfortunately, that will not help much because the optical path used for the capture was so incredibly bad. Sadly, there is really nothing you can do to improve these.
Thankyou guys, really appreciate the feedback.
I found out the original 8mm film still exists. I wonder if it would be worth having it scanned again by someone different?
I'm not familiar with this kind of medium. Have always converted Beta and VHS tape. -
You should absolutely have the film re-transferred. The difference will be stunning.
Best software for sharpening blurry video?
By CM120884 in forum EditingReplies: 15Last Post: 20th Feb 2024, 07:56 -
are there any tried and true methods of sharpening a blurry video?
By snafoo in forum EditingReplies: 11Last Post: 22nd Jan 2024, 21:31 -
How to fix blurry video on Avidemux
By satimis in forum EditingReplies: 150Last Post: 8th Mar 2022, 15:29 -
To sharpen blurry video
By satimis in forum LinuxReplies: 4Last Post: 2nd Dec 2021, 02:14 -
Original file in mp4 format from Reflecta 8mm Super 8mm scanner
By Sajmon in forum RestorationReplies: 0Last Post: 27th Feb 2021, 11:56
