I downloaded a divx-file with one frame which can not be decompressed by any player.In virtualdub it gives the same error.Whatever conversion I try it stops on that same frame ,any solution?could I remove just one frame?
It may be something more than one frame. However, it won't hurt to try to fix it, as you will still have what you start with. In Virtualdub use the mark-in mark-out tools to isolate just before and just after the problem frame. I would cut out a few frames if cutting out one won't work. Just mark the selection with the mark-in/out tools and hit delete. BTW, you can navigate frame by frame by using the arrow keys. When you have deleted it, Video >>Direct stream copy and File>>Save avi.
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 12:24 -
Panasonic ZS3 AVCHD Lite .mts - Remove Frame Repeat/Doubling?
By abnersnell in forum Video ConversionReplies: 0Last Post: 22nd Oct 2010, 20:02 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
How do I remove a bad frame from a video without VirtualDub or DivFix?
By teapot in forum Newbie / General discussionsReplies: 7Last Post: 11th Dec 2008, 19:07 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53
