Results 1 to 19 of 19
    Sep 2022
    Germany
    Hello,
    WKS-keys does not working, because it's unable to parse license.
    [Attachment 76621 - Click to enlarge]
    Protobuf 3.20.3 is installed. What's wrong? The headers.py is empty. Maybe that's the reason?
    Thanks for help!
    Dec 2021
    england
    we cant help you if you dont post video URL
    Dec 2021
    england
    you will need header
    --key 4a690a7a5360e550038739131c0f7c7c:da812b60165d3f05029c82b0b80ea113
    N_m3u8DL-RE -M format=mkv --key 4a690a7a5360e550038739131c0f7c7c:da812b60165d3f05029c82b0b80ea113 "https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/967367/2-1-1-3-2.ism/v1.mpd" --save-name video
    Sep 2022
    Germany
    Which header? Yes, the download works, but how to get the key? Thanks.
    Dec 2021
    england
    [Attachment 76625 - Click to enlarge]
    copy/paste to https://curlconverter.com/
    copy header but not all, just like that
    [Attachment 76626 - Click to enlarge]
    add pssh and lic url
    [Attachment 76627 - Click to enlarge]
    there you go
    Sep 2022
    Germany
    Thanks a lot!!!
    Sep 2022
    Germany
    Which network or developer tool is that?
    Dec 2021
    england
    yeah in network tab
    Sep 2022
    Germany
    It works! Is there a way to fetch the video in HD with N_m3u8DL-RE? I have a premium account and the video is availabe in HD.
    Normally I use yt-dlp with login and mp4decrypt and after that remux video and audio.
    Dec 2021
    england
    yeah there is, just change v2.mpd to get 1080p (3.83gb)
    N_m3u8DL-RE -M format=mkv --key 4a690a7a5360e550038739131c0f7c7c:da812b60165d3f05029c82b0b80ea113 "https://vodnowusoawsdash-cf.tvnow.de/p112/cves/sd/rtlplus/967367/2-1-1-1-2.ism/v2.mpd" --save-name video
    Sep 2022
    I have this error on Direct TV I cannot get keys in wksImage
    [Attachment 76628 - Click to enlarge]
    Sep 2022
    Germany
    Awesome. Thank you so much!
    I tried to download, but it failed.
  13. Originally Posted by iamghost View Post
    Thank you very much. This answer helped me a lot.
    I wanted to mention, that it is not the name of the .mpd file that is important, instead it is the 2-1-1-1-2.ism part.
    Sep 2022
    Germany
    The same error again now. It worked very well over months. Can you help?
    For example
    https://plus.rtl.de/video-tv/shows/rtl-aktuell-177221/2024-12-1013708/episode-338-send...3122024-968702
  15. What exact error are you talking about?
    At least for this show RTL+ has changed the widevine license url:
    https://rtlplus-widevine.streamingtech.de/index/rtlplus
    MPD for this show:
    https://vodnowusoawsdash-cf.tvnow.de/pgrn/cves/sd/rtlplus/968702/2-1-1d-3-2-1-2.ism/v1.mpd
    Decryption key:
    --key dcf3cf0f9e493ea4f0253865335799c7:72f22ddbb2f94c8ef7145ecd60fa8be0
    I haven't checked other shows, the license url may have changed for other or all shows.
    Sep 2022
    Germany
    Thank you. I changed the license url. Now it works.
  17. i got same issue
    [Attachment 84070 - Click to enlarge]
    already put header in header.py and got same problem.
    PSSH:
    AAAAUnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADIiKnZkb2 NpcGhlcjo3NWE5YzNlZmMzNmY0MmFlODA0NThkOWJlNTUzZGFh Ykjj3JWbBg==
    https://d3dac6kw5cbsk4.cloudfront.net/media/lcJE8nE0kYA28/375986a3/stream.mpd
    https://license.vdocipher.com/auth
    anyone can help me?
  18. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
