I included the recording. It would be great if you post the exact steps to fix it, so I can learn from that.
	What do you consider harsh? For example, there's really no distortions. The audio quality is simply blah.
 That said, just using some of my own Sound Forge presets, I was able to knock out some of the crowd, without really affecting the actual music much.
 Attached.Want my help? Ask here! (not via PM!)
	There's some AI separation at mvsep.com with some models trained on crowd noise, but it didn't work particularly well with this clip,
 probably too distorted.
 The examples on the site show some original "live" recordings, the crowd noise separated out and the "fixed" file.
 Some results quite impressive.
 Before submitting to the above site, I edited a small clip, used XP-era Adobe Audion 1.5 to remove some harshness
 and removed some of the reverb.
 Here's my edited source and the result from mvsep.comLast edited by davexnet; 3rd Feb 2024 at 23:39.
	That MP3 is way, way too pitchy.
 It hurts my ears even trying to listen to it.Want my help? Ask here! (not via PM!)
  How to fix the download failure with yt-dlp command for some live M3U8 linkBy zydjohn in forum Video Streaming DownloadingReplies: 12Last Post: 26th Nov 2021, 15:35
  I need a USB mic for voice recordings. windows & mac-audacity/laptop.By super8rescue in forum AudioReplies: 5Last Post: 23rd Feb 2021, 10:01
  Fix broken live streams from chromebook or Android.By OldSchool297 in forum Video ConversionReplies: 3Last Post: 10th Jan 2021, 03:26
  No sound on my MP4 video, how can i fix it?By kesis105 in forum Newbie / General discussionsReplies: 10Last Post: 15th Oct 2020, 08:49
  can't record audio all of a sudden (Sound Forge, Audacity, Vegas Pro 16)By clashradio in forum AudioReplies: 3Last Post: 8th Jul 2020, 23:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 No way: bad place (far from the scene, inside crowd, stadium) + poor microphone (smartphone?) + high compression. Perhaps costly VST like Ozone may a bit improve your recording but you won't make it by
 No way: bad place (far from the scene, inside crowd, stadium) + poor microphone (smartphone?) + high compression. Perhaps costly VST like Ozone may a bit improve your recording but you won't make it by  Visit Homepage
				Visit Homepage
