How do I remove duplicate frames from videos?
You will always have to reencode, what exactly needs to be done depends on what you want:
a. just remove them
b. remove them and turn the clip from cfr to vfr
c. replace them with an interpolation of the neigbouring frames
and what the characteristics of your source are. There are multiple ways to do this through Avisynth or Vapoursynth.
Adobe Premiere and similar NLEs also have options to do this through a gui.
If you want to use ffmpeg, mpdecimate is probably the video filter you want to look at.
Cu Selur
Ps.: you should be able to find an answer using the forum search, this has been answered before.users currently on my ignore list: deadrats, Stears555, marcorocchini -
Once I did dumb trick of decimating freezing screencapture by:
-convert video frames to png files with ffmpeg
-Find duplicate images (by md5sum or with Total Commander) and delete pngs.
-re-encode unique pngs to new video and add original audio with ffmpeg.
I got 14.5 fps vid (calculated total frames by time) still it was not freezing. -
Hi, Simple Video Editor have an function to select to delete duplicate frames, basicly just drag and drop the video or browse for it and then select Delete Dulicate Frames.. The command line can be customized by pressing ctrl and then on the save/proceed button! You might want to increase the process priority in the Windows Task Manager to get better loading times and such things! Ive tested the version 1.4.2.0 but there is newer versions avalible allso!
Remove Duplicate Images
By Jay123210599 in forum ComputerReplies: 3Last Post: 12th Jan 2024, 12:21 -
25->23.976 conversion (duplicate frames)
By sebastiaaan in forum RestorationReplies: 1Last Post: 1st Jul 2023, 03:43 -
Duplicate Frames or???
By salvo00786 in forum DVD RippingReplies: 13Last Post: 3rd Oct 2022, 14:07 -
Duplicate frames issue
By tupper in forum Video ConversionReplies: 1Last Post: 18th Dec 2019, 12:04 -
H.265 introducing duplicate frames
By ZetaStax in forum Video ConversionReplies: 22Last Post: 2nd Aug 2019, 15:58
