  1. I always do ffmpeg -i "link" -c copy "name".output
    That is only when I want the whole thing, but how do I do if I for example want a certain part of a video?
  2. ffmpeg -i "link" -ss 00:00:20 -to 00:00:30 -c copy "name".output
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  3. Originally Posted by [ss]vegeta View Post
    I don't know, but it just ends after a few seconds without taking down anything at all. Am I typing it wrong in the time stamps?
    https://www.svtplay.se/video/jXAp2GX/carina-bergfeldt/claes-bang-och-mia-parnevik-hos-...217&id=jXAp2GX
    I want it from 36:48 to 53:50. Or is it telling me I have an old version of ffmpeg? I can download pretty much everything expect this?
    C:\Windows\system32>ffmpeg -i "https://ed0.cdn.svt.se/d0/world/20240126/bfa32bb0-83d5-4175-87fb-27c394a0400e/dash-full.mpd" -ss 00:36:48 -to 00:53:50 -c copy "Johan Floderus".mkv
    ffmpeg version 6.0-full_build-www.gyan.dev Copyright (c) 2000-2023 the FFmpeg developers
      built with gcc 12.2.0 (Rev10, Built by MSYS2 project)
      configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libaribb24 --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libjxl --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libvpl --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
      libavutil      58.  2.100 / 58.  2.100
      libavcodec     60.  3.100 / 60.  3.100
      libavformat    60.  3.100 / 60.  3.100
      libavdevice    60.  1.100 / 60.  1.100
      libavfilter     9.  3.100 /  9.  3.100
      libswscale      7.  1.100 /  7.  1.100
      libswresample   4. 10.100 /  4. 10.100
      libpostproc    57.  1.100 / 57.  1.100
    Warning: program compiled against libxml 211 using older 210
    Input #0, dash, from 'https://ed0.cdn.svt.se/d0/world/20240126/bfa32bb0-83d5-4175-87fb-27c394a0400e/dash-full.mpd':
      Duration: 00:58:29.00, start: -0.043000, bitrate: 0 kb/s
      Program 0
      Stream #0:0: Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv, bt709/unknown/bt709), 1920x1080 [SAR 1:1 DAR 16:9], 1154 kb/s, 25 tbr, 12800 tbn (default)
        Metadata:
          variant_bitrate : 4494046
      Stream #0:1: Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv, bt709/unknown/bt709), 1280x720 [SAR 1:1 DAR 16:9], 647 kb/s, 25 tbr, 12800 tbn (default)
        Metadata:
          variant_bitrate : 2440115
      Stream #0:2: Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv, bt709/unknown/bt709), 960x540 [SAR 1:1 DAR 16:9], 472 kb/s, 25 tbr, 12800 tbn (default)
        Metadata:
          variant_bitrate : 1587157
      Stream #0:3: Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv, bt709/unknown/bt709), 640x360 [SAR 1:1 DAR 16:9], 306 kb/s, 25 tbr, 12800 tbn (default)
        Metadata:
          variant_bitrate : 859665
      Stream #0:4: Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv, bt709/unknown/bt709), 416x234 [SAR 1:1 DAR 16:9], 190 kb/s, 25 tbr, 12800 tbn (default)
        Metadata:
          variant_bitrate : 454859
      Stream #0:5: Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709/unknown/bt709), 1920x1080 [SAR 1:1 DAR 16:9], 1408 kb/s, 25 tbr, 12800 tbn (default)
        Metadata:
          variant_bitrate : 5434728
      Stream #0:6: Video: h264 (Main) (avc1 / 0x31637661), yuv420p(tv, bt709/unknown/bt709), 1280x720 [SAR 1:1 DAR 16:9], 987 kb/s, 25 tbr, 12800 tbn (default)
        Metadata:
          variant_bitrate : 3725923
      Stream #0:7: Video: h264 (Main) (avc1 / 0x31637661), yuv420p(tv, bt709/unknown/bt709), 960x540 [SAR 1:1 DAR 16:9], 712 kb/s, 25 tbr, 12800 tbn (default)
        Metadata:
          variant_bitrate : 2371911
      Stream #0:8: Video: h264 (Main) (avc1 / 0x31637661), yuv420p(tv, bt709/unknown/bt709), 640x360 [SAR 1:1 DAR 16:9], 492 kb/s, 25 tbr, 12800 tbn (default)
        Metadata:
          variant_bitrate : 1498144
      Stream #0:9: Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yuv420p(tv, bt709/unknown/bt709), 416x234 [SAR 1:1 DAR 16:9], 293 kb/s, 25 tbr, 12800 tbn (default)
        Metadata:
          variant_bitrate : 606425
      Stream #0:10(sv): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 192 kb/s (default)
        Metadata:
          variant_bitrate : 196721
      Stream #0:11(sv-x-tal): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 192 kb/s (default)
        Metadata:
          variant_bitrate : 197011
      Stream #0:12(sv): Subtitle: webvtt
        Metadata:
      Stream #0:13(sv): Subtitle: webvtt
        Metadata:
    Output #0, matroska, to 'Johan Floderus.mkv':
      Metadata:
        encoder         : Lavf60.3.100
      Stream #0:0: Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv, bt709/unknown/bt709), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 1154 kb/s, 25 tbr, 1k tbn (default)
        Metadata:
      Stream #0:1(sv): Audio: aac (LC) ([255][0][0][0] / 0x00FF), 48000 Hz, stereo, fltp, 192 kb/s (default)
        Metadata:
      Stream #0:2(sv): Subtitle: webvtt
        Metadata:
    Stream mapping:
      Stream #0:0 -> #0:0 (copy)
      Stream #0:10 -> #0:1 (copy)
      Stream #0:12 -> #0:2 (copy)
    Press [q] to stop, [?] for help
    [dash @ 0000021c88c73400] No longer receiving stream_index 12.77 bitrate=  -0.0kbits/s speed=N/A
    [dash @ 0000021c88c73400] No longer receiving stream_index 2
    [dash @ 0000021c88c73400] No longer receiving stream_index 3
    [dash @ 0000021c88c73400] No longer receiving stream_index 4
    [dash @ 0000021c88c73400] No longer receiving stream_index 5
    [dash @ 0000021c88c73400] No longer receiving stream_index 6
    [dash @ 0000021c88c73400] No longer receiving stream_index 7
    [dash @ 0000021c88c73400] No longer receiving stream_index 8
    [dash @ 0000021c88c73400] No longer receiving stream_index 9
    [dash @ 0000021c88c73400] No longer receiving stream_index 11
    [dash @ 0000021c88c73400] No longer receiving stream_index 13
    frame=    0 fps=0.0 q=-1.0 Lsize=       3kB time=-577014:32:22.77 bitrate=N/A speed=N/A
    video:0kB audio:0kB subtitle:0kB other streams:0kB global headers:2kB muxing overhead: unknown
  4. For me you have to download it all first, and then you can cut it.
    If you want streamcopy (no new encoding) then -ss searches for the keyframe before the specified time in seconds and -to until the specified time in seconds or -t for that many seconds from the keyframe.
    For this reason, streamcopy cannot be frame-accurate.
    If you want to be frame accurate then you have to recode, e.g.
    ffmpeg -i "input" -ss 00:00:20 -to 00:00:30 -c libx264 -crf 15 -c:a copy "output"
    See here: https://trac.ffmpeg.org/wiki/Seeking
  5. Originally Posted by Bekkeh View Post
    You can try this also
    yt-dlp "https://www.svtplay.se/video/jXAp2GX/carina-bergfeldt/claes-bang-och-mia-parnevik-hos-carina-bergfeldt?position=3217&id=jXAp2GX" --download-sections *00:36:48-00:53:50
    Worked for me.
    click click2
  6. Originally Posted by ProWo View Post
    I read everything, but I'm supposed I should read this part only?
    https://trac.ffmpeg.org/wiki/Seeking#Cuttingsmallsections
    So "input" here is the link right? Why do have "libx264" and "-crf 15" in your code? What is "a" after the c and colon?
  7. Originally Posted by [ss]vegeta View Post
    Worked for me.
    Yes, but the thing is I want to understand what I do so I don't need to rely on people here. I assume that yt-dlp works in ffmpeg ?
  8. Originally Posted by Bekkeh View Post
    yt-dlp works WITH ffmpeg
    just have them in your PATH
    click click2
