  1. Banned
    Nov 2022
    Say, I have a recording with some audio plus constant noise, and I also have a file with noise only. Is there a simple tool to remove the noise from the first file using the second file as a hint?
  2. If the noise on the 2nd file is an exact replica of the (additive) noise in the first file you could simply subtract it (noise cancellation).
    If the noise on the 2 files are random the difference will still be random noise. So no improvement.
  3. Banned
    Nov 2022
    It is not the exact replica, but the same kind of an annoying high pitch whine. I am expecting some sort of Fourier transform magic.
  4. Member Cornucopia's Avatar
    What you are wanting to do is called audio deconvolution. Izotope's RX, WaveArts, and other tools do a pretty good job at matching a noise's impulse response and being able to minimize it (if not fully subtract it) from a desired signal. There are some freeware alternatives out there as well (deconvolv, voxengo, etc) although they aren't nearly as successful nor as convenient.
  5. Why not use a sample from the original recording for your noise reduction?
  6. There is many possibilities - for example you can try to use SoX.
    https://stackoverflow.com/questions/44159621/how-to-denoise-audio-with-sox
    FFmpeg also offer audio denoise filters:
    https://ffmpeg.org/ffmpeg-filters.html#afftdn
    https://ffmpeg.org/ffmpeg-filters.html#afwtdn
    For graphical interface you can use Audacity
    https://support.audacityteam.org/repairing-audio/noise-reduction-removal
    Personally i use old Audition - there is neat option there - remove everything else than noise - thanks to this you can try to create proper noise profile - by hearing only noise you can find accurate level where nothing except noise is heard (so no tonal sounds, no residual sounds from signal - this is proper noise profile)
  7. Originally Posted by Bwaak View Post
    You can usually remove that with a tight notch filter of the fundamental and harmonics.
