There is a semi transparent piece of writing that's at the boom of the screen for the entire video.
Is it possible to use AI or anything to get rid of it?
[Attachment 76481 - Click to enlarge] It's the semi transparent writing, and not the preview text
Thanks in advance
should be possible with InpaintDelogo (https://forum.doom9.org/showthread.php?t=176860, https://forum.videohelp.com/threads/403535-InpaintDelogo)
VoodooFX probably will tell you how, if you share a small clip, ideally with the logo before a black or mono color background.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
What is required - I have never dealt with delabling before, but willing to take the risk. Will send small sample of video if required
Then should be easily removable.
The first requirement: Do you know how to use Avisynth? -
You can preview avs scripts with various programs. AvsPmod for an example.
Removing Shadow?
By meeshu in forum Newbie / General discussionsReplies: 11Last Post: 13th May 2023, 23:15 -
Removing subtitles
By jarod1005 in forum Newbie / General discussionsReplies: 6Last Post: 6th Feb 2023, 13:21 -
CD/DVD/BD Label and Cover Making Software
By User897 in forum ComputerReplies: 12Last Post: 9th Jul 2022, 15:50 -
Removing frames?
By Chauceratemyhamster in forum EditingReplies: 12Last Post: 4th Jul 2020, 14:42 -
Removing Chroma
By cfelicio in forum RestorationReplies: 2Last Post: 3rd May 2020, 16:17
