PSSH:
License:Code:AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABgSEHLHJBslQkY0l8BLZBKlRPtI49yVmwY=
Headers:Code:https://drm.content.foxtel.com.au/licenseServer/widevine/v1/foxtelott/license?contentId=c9907c9e-7ff3-4754-b2e6-ce956df6f197-MD168042-AVC-1680366151
Hey guys,Code:headers = { 'authority': 'drm.content.foxtel.com.au', 'accept': '*/*', 'accept-language': 'zh-CN,zh;q=0.9,en;q=0.8', 'authorization': 'Bearer eyJraWQiOiI3a0UxeCt4bE5xbFJabHNaMm9NeStQNnlBckU9IiwidHlwIjoiSldUIiwiYWxnIjoiUlMyNTYifQ.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.GHo-TiadJLJ5EA8UfTyFHxXXVJGGcd-iy0DPi7Xa0IEbUuU6pjfllnQvd2s8lptl_1hhIDRdyVKgVzYkHgV3nvqUEHDVJzrgHJQ-OaS9-dAQyK6v1jinzJ2RyXXNA1AoL-HbfCBRnHbnSBeBOEbbr8KWbNEDNFuJzqxR2mgCOz3kY7otWdF47g7LuTunGhoDuXrsXJrr__09CfPBDFXN3ufE6Qy_A12y9H8v07HjM9nG1AZPgn9-s_VldGCvp8rBSbhSLTuUJ67Z93G4ov8unRgs63Fn6yyNHRWGuCMJl-mRAzLvLLEtFB3gs_tOj_R592vDu7v8OKhq50h_Smf_Cw', 'cache-control': 'no-cache', 'dnt': '1', 'origin': 'https://binge.com.au', 'pragma': 'no-cache', 'referer': 'https://binge.com.au/shows/show-celebrity-family-feud!9926/season-season-7!15525', 'sec-ch-ua': '"Not A(Brand";v="99", "Google Chrome";v="121", "Chromium";v="121"', 'sec-ch-ua-mobile': '?0', 'sec-ch-ua-platform': '"Windows"', 'sec-fetch-dest': 'empty', 'sec-fetch-mode': 'cors', 'sec-fetch-site': 'cross-site', 'user-agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36', 'content-type': 'application/x-www-form-urlencoded', }
It went fine when streaming on Chrome, but it always returned an 403 when sending a POST using Python.
Have checked that my CDM are indeed working, as well as the PSSH is right.
P.S.
Manifest:
IP restriction: Australian IP needed.Code:https://vod-avc-drm7-cf.foxtelgroupcdn.net.au/out/v1/bef8fab1423346f8875c2e3c5207e43d/b5d724ada4494ebbb8bd55489ea091aa/545bda3186e148d586c7e9d72422b834/index.mpd?aws.manifestfilter=trickplay_height%3A1-2
I remember I could get the key without a problem in early 2023. But not anymore now.
Results 1 to 28 of 28
Ah, yes, it belongs to kayosport.
But I have no idea about the TLS fingerprint you mentioned. -
Yes, they use TLS fingerprinting. Which basically means that the server rejects libraries like requests and httpx. The simplest way around it is to use something pycURL or similar.
... like maybe https://pypi.org/project/curl-cffi/ - which can impersonate chrome110. I've not tested this myself though.
Yes, using curl_cffi is OK.
main codes:
Code:from curl_cffi import requests ... widevine_license = requests.post(url=..., data=..., headers=..., impersonate="chrome110")
Last edited by CrymanChen; 26th Jan 2024 at 10:27. Reason: Changed 'POST' to 'post'
Any ideas please
module 'curl_cffi.requests' has no attribute 'POST' -
Hi I know this is somewhat vague, but I'm trying to run a python script that is using curl_cffi and after pressing enter, all I get is d' ' ? I have tried googling and I see mentions of being perhaps a token issue or something to do with bytes. As I said, vague but I thought someone may have come across something similar.
I am definitely running within 5 minute periodif you do it totally manually, the Bearer token in license header expired after 5 minutes. usually it's enough if you live in AUS.
I am getting 400 error when using curl_cffi for license request and 403 error when using standard requests. Can anyone see the issue??
Code:PSSH_VALUE = 'AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEPVyVqk6REC1i/2su82H4yk=' token = video_id = 5036703 res = requests.post( url='https://api.stan.com.au/concurrency/v1/streams?jwToken={}&programId={}&stanName=Stan-AndroidTV&quality=ultra&format=dash'.format(token, video_id), headers={ "jwToken": token, "format": "json", "capabilities.drm": "widevine", "videoCodec": 'h265' }, impersonate="chrome110" ) data = res.json() keyId = data['media']['drm']['keyId'] license_token = data['media']['drm']['customData'] mpdurl = data['media']['videoUrl'].split('?')[0] license_url = data['media']['drm']['licenseServerUrl'] + f'?specConform=true&jwToken={token}' headers = { 'Accept': '*/*', 'Accept-Encoding': 'gzip, deflate, br, zstd', 'Accept-Language': 'en-US,en;q=0.9', 'dt-custom-data': } pssh = PSSH(PSSH_VALUE) device = Device.load(WVD_FILE) cdm = Cdm.from_device(device) session_id = cdm.open() challenge = cdm.get_license_challenge(session_id, pssh) licence = requests.post(url=license_url, headers=headers, data=challenge, impersonate="chrome120") licence.raise_for_status() cdm.parse_license(session_id, licence.content) for key in cdm.get_keys(session_id): print(f"[{key.type}] {key.kid.hex}:{key.key.hex()}") cdm.close(session_id)Last edited by breadcomb; 8th Aug 2024 at 08:14.
Use code tags to format your script. Otherwise it gets messed up with additional spaces added in long strings.
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
@breadcomb:
I'd highly recommend you to remove any tokens when posting scripts. Some of them contain sensitive information. -
That's an issue somebody using WidevineFetch reported. I'd be happy if we could find a solution, as I also wasn't able to get keys from stan.
Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2 -
Binge works with WidevineGuesser but I've just about given up with the whole Binge/Kayo/Foxtel circus nowadays. They run very aggressive bots that will get your account closed the minute they identify anything the least bit unusual. Even running singe thread downloads spread way out has cost me numerous accounts in the last 12 months.
sounds weird, which license url you used? original one
or with params one?Code:https://lic.drmtoday.com/license-proxy-widevine/cenc/
Code:https://lic.drmtoday.com/license-proxy-widevine/cenc/?specConform=true
i tested a few month ago with original license url(which i suggest) and parse json response, it worked with stan. i cant remember if i used an AUS vpn, probably not. -
I mainly tried around with the 'specConform' one, but also tried the one without. Could try and see if it still works?
Do you still have access to the site? So we could compare our results
no, i used other people's account, he had changed pw. and yes for the safe as stablebrick said, dont post custom-data on forum
@shellcmd
How can I contact you privately? I got permission to share a stan account with youBypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2 -
discord is ok. I just need you send me a pssh and dt-custom-data to get the keys, no need login. just a test, if I failed, means they maybe made some changes.
403: (access denied) Error While Writing Zee5 Live Tv Using Ffmmeg
By StarkGang in forum Video Streaming DownloadingReplies: 1Last Post: 9th Jun 2021, 00:44 -
TMPGEnc Authoring works 4 - Access is Denied (Error code 0x80070005)
By The Roo in forum Newbie / General discussionsReplies: 3Last Post: 17th Mar 2021, 17:34 -
ffmpeg HTTP 403 Forbidden
By xerp in forum Video Streaming DownloadingReplies: 3Last Post: 4th Sep 2020, 13:22 -
Tryng to download from animal planet... HTTP error 403 Forbidden
By syrist in forum Video Streaming DownloadingReplies: 3Last Post: 15th May 2020, 19:38 -
download afreecatv steaming with ffmpeg get HTTP error 403 Forbidden
By j2ee in forum Video Streaming DownloadingReplies: 1Last Post: 30th Apr 2020, 09:13
