I want to set up FFMPEG to send out an RTSP stream as a server, so that FFMPEG listens for an incoming connection from an RTSP client, and upon connection sends video to that client. I can't find anything about how to do this on the internet. The only things that I can find are how to use FFMPEG to receive a stream from another server, or how to have FFMPEG act as a stream source client to send video to a third party server (FFMPEG acts as a client to connect to server and stream video to server, and then the person wanting to view the video uses a normal RTSP viewing client to watch the video from the server). But this requires the server to be some other software, and it's a midpoint in the stream (total number of points in the system is 3). I want to use FFMPEG as the source endpoint of the stream, and be a server (so there's only 2 points in the system, source server and viewing client), so that the client will connect directly to FFMPEG to view the stream (the video content will be a live stream from from a webcam).
Hey, if cant find anything on the internet, maybe the RealMedia with Variable Bitrate (.rmvb) + Helix Server can hep you out, there is some free stuff to get ahold of, both for producing RealMedia with variable bitrate and look like an Helix Server can be obtained for free allso!
I think with that you can broadcast/stream using the rtsp!
Edit: Ellse if you're using an webcam maybe the FFMpegGUI can help, it got some RTSP stuff and capture from directshow devices and such stuff, untested from my part, still just looking into the RealMedia thing + Helix server myself so maybe cant get the camera going there i dont know!Last edited by Swedaniel; 26th Jan 2024 at 10:07.
October262's link looks very good
However if you would like stream to Youtube (RTMP) you can use this
https://projects.raspberrypi.org/en/projects/infrared-bird-box/10
MPC BE: RTSP stream from file
By Crapozo in forum Newbie / General discussionsReplies: 0Last Post: 27th Nov 2021, 23:26 -
Redirecting RTSP stream
By tzimber in forum Newbie / General discussionsReplies: 2Last Post: 23rd Nov 2021, 15:57 -
FFMPEG Save video from rtsp stream to hls stream
By Wisperrio in forum Video Streaming DownloadingReplies: 2Last Post: 26th Aug 2021, 22:38 -
How can I capture RTSP stream with FFMPEG continously and later decode
By bcalbatros in forum Video Streaming DownloadingReplies: 0Last Post: 17th Apr 2020, 13:01 -
Convert MPTS to RTSP Stream Output
By Dariofil in forum DVB / IPTVReplies: 1Last Post: 25th Jun 2019, 22:08
