i have a restoration script that works pretty well for my materials. nothing like what johnmeyer and videofred have done but it does make my old film material look good. it's painfully slow, though.
in playing with the scripts from johnmeyer and videofred, i've found just how much of a difference multithreading and memory make to render time. i've put 'SetMemoryMax(24576)' into the script and it made a huge difference (i have 32gb). i've not been able to figure out how to get multithreading to work, though. i have twelve cores. for the testing i did on john meyer's script i used nine threads and it made a significant difference. can anyone post what i need to add/change to get that working? here's my script:thanks,Code:import("/home/babag/.wine/drive_c/Program Files (x86)/AviSynth+/plugins+/RemoveDirtMC.avs") FFMPEGSource2("input.mov", atrack=1) #LSmashVideoSource("input.mov") z_ConvertFormat(pixel_type="YUV420P16") # Preserve 10 bit #threads=9 SetMemoryMax(24576) BilinearResize(width/2, height/2) KNLMeansCL(d=1, h=1.6, a=1, s=4) RemoveDirtMC(60, false) UnsharpMask2(strength=50, radius=2, threshold=0) nnedi3_rpow2(2, cshift="Spline36Resize") KNLMeansCL(d=1, h=10, a=2, s=4) GrainFactory3(g1str=39, g2str=45, g3str=0, g1shrp=100, g2shrp=100, g3shrp=100, g1size=4.00, g2size=4.00, g3size=0.5, g1tex=30, g2tex=30, g3tex=30, temp_avg=0, th1=24, th2=56, th3=128, th4=160, ontop_grain=10) Sharpen(0.50) # Accepts values -1.58 to 1.0 Levels(4400,1.2,65535,0,65535, false) # 16 bit values #Prefetch(9)
babag
Results 1 to 14 of 14
a. read: http://avisynth.nl/index.php/SetFilterMTMode
b. try adding:
at the topCode:SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE)
and add back the
at the end.Code:Prefetch(9)
But no clue whether this will work at all in wine,...
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
thanks, selur.
tried your suggestions and am getting an error regarding masktools2 and knlmeanscl.
as for wine, i've gotten most of johnmeyers restoration script to run as well as videofred's stabilisation script. also, many simpler ones of my own so i don't think wine is an issue. on the other hand, i know next to nothing about this stuff and am pretty much restricted to copy/pasting things people here and elsewhere tell me to.
thanks again,
babag -
I hope you don't expect anyone to guess what that error might be?tried your suggestions and am getting an error regarding masktools2 and knlmeanscl.users currently on my ignore list: deadrats, Stears555, marcorocchini
you're gonna take all the fun out of it!
it seemed odd to me and redundant and long for retyping in here so i wasn't sure what to do. hope this makes sense to someone.Code:Avisynth read error: masktools2 error on invoking "Expr" call with use_expr: masktools2 error on invoking "Expr"call with use_expr: KNLMeansCL: fatal error! (AviSynthGetFrame)
when i open the script in virtualdub2, the screen is gray. if i try to render the file, or a section of it, i get the above error.
thanks (and sorry),
babag -
I assume you are using Avisynth+, right?
What masktools2 version are you using? Masktools v2.2.30 (20220219) from https://github.com/pinterf/masktools/releases/ ?
For KNLMeansCL, which requires opencl I suspect a problem with wine. Does it make a difference if you use device_type="cpu" ?
Cu Selur
Ps.: I would recommend to move the sharpen over the GrainFactory3 call, assuming you do not want to increase the sharpness of the grain you are adding.users currently on my ignore list: deadrats, Stears555, marcorocchini -
thanks again, selur.
yes to both the avisynth and masktools2 questions. yes it's avisynth+ and yes, it's the version of masktools2 you reference.
how would i use the device_type="cpu" code? is that a standalone line? a parameter for something else? if standalone, where would i put it? beginning? end? somewhere specific in the middle?
thanksd,
babag -
placing the device_type="cpu" code at the start of the script changes the error. now it's just:
frames still appear as gray in virtualdub2.Code:Avisynth read error: KNLMeansCL: fatal error! _AviSynthGetFrame)
babag -
device_type is a parameter for KNLMeansCL, see: http://avisynth.nl/index.php/KNLMeansCL
so change:
toCode:KNLMeansCL(d=1, h=10, a=2, s=4)
Code:KNLMeansCL(d=1, h=10, a=2, s=4, device_type="cpu")
ah! thanks.
changed to as you suggest and get new error:fwiw, this script runs fine until i try to invoke multithreading.Code:Avisynth open failure: KNLMeansCL: no compatible opencl platforms available! (z:\path\to\input.avs, line 104)
thanks again,
babag -
Then its some issue with wine (or the runtimes it uses), all those filters run fine with multithreading on Windows itself.fine until i try to invoke multithreading.users currently on my ignore list: deadrats, Stears555, marcorocchini
do you know of an alternative to knlmeanscl that i could try substituting?
thanks,
babag -
fft3dfilter, neo_fft3d, hqdn3d, xNLMeans
see over at: http://avisynth.nl/index.php/External_filtersusers currently on my ignore list: deadrats, Stears555, marcorocchini
https://forum.videohelp.com/threads/407937-Download-video-from-IQ-com-or-QS
By littlewest in forum Video Streaming DownloadingReplies: 13Last Post: 19th Dec 2022, 06:01 -
Threads/pools with Virtualdub2?
By smike in forum EditingReplies: 1Last Post: 10th Jun 2022, 21:43 -
Limiting x264 threads (HandBrakeCLI)
By frist13 in forum Newbie / General discussionsReplies: 0Last Post: 27th Feb 2022, 01:20 -
x264 threads
By alkoon in forum Video ConversionReplies: 5Last Post: 23rd Nov 2020, 01:22 -
FFMPEG lookahead threads default to 1?
By tony95 in forum Video ConversionReplies: 2Last Post: 15th Sep 2019, 09:02
