Can anyone please explain why some standalone DVD's have problems with SVCD ?
If I understand correctly SVCD and DVD are both mpeg-2 video, Mpeg-1 layer-2 sound. My DVD has problems with SVCD at any bitrate while it works fine for VCD at bitrates up to 2500 kbit/s so I don't think its a bit rate issue.
can the autoring program (nero) be the cause ?? Or the encoder (TMPGENC) ?
Thanks,
Some stand-alones seem to have problems above a certain bitrate. Try this test:
Encode a SVCD using CQ setting:
Max bitrate 1850
Min bitrate 755
Quality 50 - 65 (you can go higher, but you probably won't notice much diference)
I find one of my DVD players will only play these, whilst anything with a higher bitrate falters. Even if I knock down the bitrate with 2-pass VBR, it still only plays the CQ encoded SVCDs properly!.
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
