I came to Video Help to find the answer but didn't - well not quite.
I had been using WinDV for a few tapes in my Canon MV5i MC miniDV cam with no problem then came the error 'Cannot find DV output pin'
My solution was to remove the firewire driver, reboot the PC, let Win 7 find and reload the firewire driver.
Result no error message and WinDV working again.
I think what corrupted the driver was loading Adobe Premier 2. I have used this with no problems in the past.
I removed it and the firewire driver and WinDV worked again.
I couldn't use my Win 10 i7 desktop because the motherboard didn't have a spare slot for the firewire card and USB didn't work with the camera. So I had to go 'old school' and match the old camera to an old computer running old software which worked fine.
I had the same error message "cannot find DV output pin" and followed all advice, including installation of legacy drivers, but nothing worked until I unplugged my USB webcam. Once I had done that, I was able to choose Microsoft DV and camera as the input device in WinDV and everything worked immediately.
By RalphW in forum Capturing and VCRReplies: 11Last Post: 23rd Jan 2024, 15:14 -
Cant find audio output
By sansin12 in forum Newbie / General discussionsReplies: 6Last Post: 5th Sep 2021, 22:02 -
Need help to find Avisynth solution for Luma issue on video
By Fonzzie31 in forum RestorationReplies: 1Last Post: 15th Jun 2021, 06:07 -
Can't find suitable output format for X265
By smike in forum EditingReplies: 5Last Post: 30th Nov 2020, 07:18 -
Trying To Find Solution for playing 1996 AVI file created with a WebCam
By Jeff90046 in forum Newbie / General discussionsReplies: 9Last Post: 29th Dec 2019, 21:55
