  1. I can download a BBC Sounds programme when doing this:
    get_iplayer https://www.bbc.co.uk/programmes/m001v3z4
    I then try setting the same as the above but also adding a download directory like this:
    get_iplayer https://www.bbc.co.uk/programmes/m001v3z4 --output “L:/Podcasts/The Retro Hour Podcast"
    But it gives this error:
    Episodes:
    Sliced Bread Presents - Toast - Sunny Delight, BBC Radio 4, m001v3z4
    INFO: 1 total programmes
    INFO: Processing radio: 'Sliced Bread Presents - Toast - Sunny Delight (m001v3z4
    INFO: Downloading radio: 'Sliced Bread Presents - Toast - Sunny Delight (m001v3z
    4) [podcast]'
    ERROR: Could not create dir 'C:\Users\Dave\“L:\Podcasts\The': mkdir C:\User
    s\Dave\“L:\: Invalid argument; The filename, directory name, or volume labe
    l syntax is incorrect at C:\Program Files\get_iplayer\get_iplayer.pl line 3463.
    What am I doing wrong?
    Verbose log attached
  2. Thanks, I'll take a look at Freevine the next time I want to download a video. Interesting that you can download from ITVx, Channel 4 and Channel 5 as I was always under the impression that that was impossible. How long did it take you to crack their DRM?
    Thanks for that MP3 but I was looking for the AAC 324 Kbps source. YouTube DLP can get that but I was trying to see what format get_iPlayer would download. Do you know how to do that as per my original post?
    Can your program download audio or only videos?
  3. The error message shows you the problem. You made a typo in your command. You didn't quote the directory path properly.
  4. Originally Posted by ilainftw View Post
    I can't see the error there. Can you point it out please. Can you give me the correct code please.
  5. Originally Posted by VideoFanatic View Post
    the quote character that you had before L: is not the like the other quote so best to delete it and re-type it
    get_iplayer https://www.bbc.co.uk/programmes/m001v3z4 --output "L:/Podcasts/The Retro Hour Podcast"
