    Jan 2024
    Amsterdam
    Hi everyone, I'm new to the forum and I really could use some help exporting video's from premiere pro to thes specific characteristics found below. If anyone can help me setup a preset I would be for ever greatful
    Complete name : video.mpg
    Format : MPEG-TS
    File size : 2.25 GiB
    Duration : 2 h 9 min
    Overall bit rate mode : Constant
    Overall bit rate : 2 500 kb/s
    Frame rate : 25.000 FPS
    FileExtension_Invalid : ts m2t m2s m4t m4s tmf ts tp trp ty
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : Main@L3
    Format settings : CABAC / 2 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference frames : 2 frames
    Codec ID : 27
    Bit rate mode : Constant
    Bit rate : 2 118 kb/s
    Nominal bit rate : 2 000 kb/s
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.204
    Stream size : 1.91 GiB (85%)
    Writing library : x264 core 155
    Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=19 / lookahead_threads=3 / sliced_threads=0 / slices=1 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / stitchable=1 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=1 / keyint=25 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=25 / rc=cbr / mbtree=1 / bitrate=2000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=2000 / vbv_bufsize=2000 / nal_hrd=cbr / filler=1 / ip_ratio=1.40 / aq=3:1.00
    Audio
    Menu ID : 1 (0x1)
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Codec ID : 3
    Bit rate : 256 kb/s
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz
    Frame rate : 41.667 FPS (1152 SPF)
    Compression mode : Lossy
    Stream size : 236 MiB (10%)
    Language : English
  2. I'm not using premiere pro, but the specs are:
    Video: codec x264 (avc), 25fps PAL, profile main@L3, 8 Bit, resolution 720x576, DAR 16:9, bitrate 2000 kb/s, chroma subsampling 4:2:0, colorspace YUV
    Audio: codec mp2, bitrate 236 kb/s, stereo, frequency 48.0 kHz
    Search for this settings in premiere pro.
    Jan 2024
    Amsterdam
    Thanks for you reply, great help. I just can't get my export to comply with the MPEG-TS format with these settings.
  4. Originally Posted by julianusss1283 View Post
    You must export to ts, not to mpg.
    See your post #1:
