I really do not think that is possible. I believe all vdub external encoders rely upon ffmpeg (but I may be wrong on that).
AFAIK you have two options to use HCenc as your encoder.
1. Use one of the HC GUIs as shown in the software section.
2. If your mpeg2 video is to be dvd-compliant you can use avstodvd. Choose a simple mpeg2 video as the export type (rather than a dvd-folder) and you can select (not the default) HC as the encoder.
AVI TO MPEG2 encode
By FelipeArchives in forum Capturing and VCRReplies: 32Last Post: 14th Mar 2023, 06:43 -
Using TMPGEnc Master Works 7 to encode DV-AVI to mpeg2......Best settings.
By Purple2112 in forum Video ConversionReplies: 112Last Post: 12th Jun 2022, 16:20 -
I have mkv files( mpeg2) how i can put them back dvd without re-encode
By GamlaGubbe in forum Authoring (DVD)Replies: 2Last Post: 11th Oct 2021, 17:15 -
how to force ffmpeg to encode mpeg2 interlaced ?
By hydra3333 in forum Video ConversionReplies: 19Last Post: 25th Jun 2021, 08:22 -
Encode closed captions embedded into MPEG2 video?
By Tanz76 in forum SubtitleReplies: 5Last Post: 19th Apr 2020, 16:24
