Hi all,
after chasing 3 adapters, I am finally able to capture from my 20+ year old digital 8 camera. I was very happy to see Final Cut immediately recognizing the camera with video and audio.
Once I started import, at first it seemed it was correctly creating individual clips from each time I started and stopped shooting. But most of the time it's actually making random short clips of a second or two.
Do you know why what could be causing it?
If there is no solution, it might be better to just capture the entire 60 second clip.
Thank you
Huh, it seems it was not possible 12 years ago, which is crazy: https://discussions.apple.com/thread/3608661?sortBy=best
Have you tried importing with QuickTime? If not, then some other tool/NLE like Premiere.
Originally Posted by Alchroma -
Hi. Thanks for responding. Now it's possible to automatically capture each scene in a new clip (and might be the only current option with FCPX), but it's not what's happening. It's clipping within a scene. A scene of let's say 10 seconds, has 10 clips of 1 second.
Someone mentioned it can be because the tapes are old and might not be playing smoothly, creating drops, and FCPX thinks it's a new scene. I don't know if that's the case.
If I can't solve it, I guess will have to capture all 60 minutes with QT.
Burning DVD of many short clips while merging some
By verella in forum Newbie / General discussionsReplies: 5Last Post: 27th Aug 2022, 06:01 -
Many films edited in Final Cut Pro X now!
By joejonas in forum Latest Video NewsReplies: 9Last Post: 22nd Jul 2020, 09:51 -
Capturing in Final Cut Pro. Unstable timecode force closed software.
By nicetimes in forum Capturing and VCRReplies: 0Last Post: 17th Jul 2020, 15:10 -
Make short video clips slide across the screen
By yuppicide0138 in forum EditingReplies: 3Last Post: 28th Jun 2019, 14:00 -
Best Final Cut Pro tutorial
By offtheroad in forum Newbie / General discussionsReplies: 10Last Post: 11th Mar 2019, 09:45
