Audio but no video sent from Apple box to DVD Pioneer recorder. Just used converter HDMI to yellow white and red to send signal from apple box to Pionner dvr 660 but video is not coming, only audio. Help please. Thanks
Results 1 to 9 of 9
What is this "Apple Box" ? HD ?
A dvd-recorder can only record SD signals and mpeg2 at that. -
You already stated that so you add nothing to the discussion.
One needs to know what signal is initially received by this 'Apple Box'. Audio is different to video. So if the video signal is, for example, h264(AVC) there is no way - not even allowing for any possible High Definition Copy Protection (HDCP), as stated above, - a simple adapter which merely converts a HD signal to a composite one will not work. Yes, the audio could pass through but the recorder must receive SD mpeg2 VIDEO which one only receives these days from analog sources.
And if you can not answer the question just tell the model no etc of the 'Apple Box'Last edited by DB83; 22nd Jan 2024 at 03:46. Reason: typo
Still not terriby helpful so one must assume that the incoming signal really is HD.
So it's not directly possible for reasons alread stated. And even if you can defeat HDCP (some hdmi splitters can do this) you will still have non-SD video to contend with.
I suggest that if you really want to record from the box then you need to invest in a HD recorder + a compatable splitter (you can search the forums about this but be warned that what might have worked in the past may not do so now) -
DRM + no downconverter = no video
this is apple box
https://en.wikipedia.org/wiki/Apple_boxmake video everyday
Passthrough DVD recorder but it is SECAM-L and has S-Video Input/Output
By JadHC in forum RestorationReplies: 26Last Post: 14th Sep 2023, 06:16 -
How To Get DVD recorder to REcognize Cable Box Video Out as L1 Input
By Novice20 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 21st Jun 2023, 17:36 -
LG Dvd Recoder/video Cassette Recorder RC6921W Writing Problem
By zappfra in forum DVD & Blu-ray RecordersReplies: 6Last Post: 16th Feb 2022, 22:38 -
Apple TV with GSE IPTV ..vs.. Andriod Box
By VirtualDoobMon in forum Media Center PC / MediaCentersReplies: 0Last Post: 6th Apr 2021, 19:38 -
Looking for a media player TV box, which reads USB sticks, and E-AC-3 audio
By Gary King in forum Media Center PC / MediaCentersReplies: 6Last Post: 14th Jan 2020, 17:35
