I have a large collection of ripped DVD TV shows. The files are VOB files ripped from the DVD, with 1 VOB file per episode. I would like to re-encode these to h264. I'm looking for something that can do this in batches, with a way to specify cropping parameters (to eliminate the old 90s TV overscan), and good quality re-encoding. What are the best options? Thanks.
You can add the videos one by one to something like VidCoder and adding the job to the queue.
This works after setting up the encoding settings to do the autocrop.
Also came across this script that works, but only one file at a time. Perhaps someone can modifiy it
to work on a folder full of files, or mutilple files selected, drag and drop
https://forum.videohelp.com/threads/393152-Auto-Crop-Black-Borders?highlight=cropdetect#post2653132 -
Are all .vobs to be cropped the same? If so, I would suggest to specify the cropping explicitly as Autocrop sometimes fails (cropping too much in dark scenes, for example).
Convert H266 to H264 program?
By QvidZ in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2023, 23:36 -
FFMPEG deinterlace before SD h264 encode in one batch possible ?
By Gwar in forum Video ConversionReplies: 10Last Post: 30th Oct 2022, 19:51 -
RIP Thunderbirds DVDs to MKV using Handbrake: 2 VOBs to one MKV?
By JDMils in forum DVD RippingReplies: 2Last Post: 7th Jun 2021, 21:18 -
Convert HEVC to H264 Blu Ray
By luciofulci in forum Video ConversionReplies: 3Last Post: 31st May 2019, 13:14 -
Avisynth - just use the VOBs or convert the VOBs to MPG first?
By pooksahib in forum Video ConversionReplies: 5Last Post: 28th May 2019, 02:51
