  1. what do i select NTCS or PAL? im sorry but i am very new to this
    Dec 2001
    USA
    It depends in what part of the world you live in. As to what TV format to use. NTCS is in North America and Japan and ? PAL is Europe and?
    May the force be with you.
    Mar 2002
    chicago
    pick whatever your source is
    open the vile in virtualdub, and under file->file properties
    25fps=PAL
    29.976fps=NTSC
    23.976fps=NTSCfilm
    pick the corresponding template in TMPG and encode.
    if you have problems with playback aferwards, you might need to do a format conversion. if that is the case, search the forum and guides, and you'll find out how to do that properly
