Hello.
I can't get a key from canalplus.com (FR) anymore, even StreamFab doesn't work at all.
The licence seems to have been modified, there is a drmId now: https://secure-gen-hapi.canal-plus.com/conso/view/d7706570-b861-11ee;d7706570-b861-11e...fig=mkpl::true
Results 1 to 17 of 17
license is normal, trick in response, it is xml format, you can search the forum, someone had given the solution.
append:
all right, i check your link carefully, yes it is not same as i saw before. -
As an example, Fargo S05E02: https://www.canalplus.com/series/fargo/h/10028027_50001/saison-5/
The following error occurred:AAAAYHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAEAIARIQ9T jOJ01nTPOJyxxBrm7MrBoIV2lkZXZpbmUiGjAxSEs4MFEyWVhX NkhCQUszWTQ5MjhRNUpGSOPclZsG
https://secure-gen-hapi.canal-plus.com/conso/view/752dea70-b872-11ee;752dea70-b872-11e...fig=mkpl::trueSyntaxWarning: invalid escape sequence '\/'
license = re.search(".*<license contentid=\"(.*)\">(.*)<\/license>", str(widevine_license.content))[2] -
A modified WKS-KEYS version.
Lic: https://secure-gen-hapi.canal-plus.com/conso/view/a219cf40-b87c-11ee;a219cf40-b87c-11e...fig=mkpl::true
Token="11101ceMeX_SJCkBOThRNbz5Dl3sWYVsq918174EfPR Fc8bZ5VnX8w-iolXSG71_yXRXftWiJqeBvkFHoCPPA3weRTFwQPiEKhq1Zob2o 0oVCDZInRRR4IkX_C7bPI8qHUBc5tbZ8fJzrND1K9AGp-Gy7aRYCKilnn47g6b3zwTc4PcW4Mllx0tzpN7pGgQANUJfnX0z cCjwhaT2-ywxU5AjMwFt6KAi61JHkLrvsVuekILJF_hyNuZvibm0VSaYc1K 8KmglQEL0t1SFvTi1N1ktTXpPkprdgxqcA43LBCzgHbxp1PrgZ n2Nlos5KFNOvXoGrwcyddyXdRuFHOSItjCcUU272Madkscx3qA KPzsdEEs5m9VoCXaz8jvbv4-DMgl9IYFAtPJwBJxQWVfGyu5MJNFflGDlcipoDbNJo4d-1J2Kg2WyFenQSKP9dBE7tnrGkU9J2PFUXyWgnwCZ1JShj_gtY0 QtBTwtkQATfS9BN8i82Vj4cOK8EMR4hqw2qJT4TGnLk8Ikwuoe MqYTK4uXL1IswDJ0PdEIlbWmvBU78WH0_xpCYvIV3vMIaXASd4 op6VovLjWWwy1xXknIWP42U0StAP6X5qN_DXnhO3NzwOAfkt39 2puEzkbXIki123AB8e6vrw5tP0qlvoZWYhQeU_ZVBsCF6W8Js6 17hnlJYN_fFQHuQMCsmh_bPPQTmnsKVQnwr4CJ-9UMrnTD8B6G6pZJoc8ZBpLr5ta5Qhs_FioekDzrbOBm1K_Tv5I 42sSftHZ3bIt3VJkotlekbC1F9ylbAEdff727nSXuWc4BJm3zw anQmas8afSXcqkw_dKb6B9eEdHfVaa8aqVsI5HBAt9Pdo0kKGE c0wtPobMAYzt9W8hrONE-Q6uySeUdQGJh3phddpX7D8uUbr6tWn7OzTiq-XG9yONsN0yt5l-FQ6xugl-j6MrygNQeKksLCD0sby1vtj4GYOKwTSwU1BcHfKmxu3QlSXMax sEFYpkN4fYP1y7jULBYk9l3NWVlYj8hYG_ZbsulRRk8kCNVLzZ 6H0cJAUZ_IFX2EzdhYjLSutAeF2LhiuU6fQY4ZKOVNFgK7st_J 4QAUh0WFo0FyOEVWNOEn4I52rzcRFpUOSarYukhnvRHJbR2lDP JHefYUn8a0_Nx6kBBZ__OmpRnplMUEIeBreNbkYZylKBnG9l6Q MNtUFHatmjHhbBugFJHn9vu3DIfRIU0SGFMPuoAV87G31bxj5y dTuCiGrY3hcA2NuH-KG3o39mB0cJKz6AROU9Le0mGPkEe2PZBfUXSxEIGcHYPODbVdL TC2TxDJZPDjLdUEKbtBPEIFM67ibbF8bQQdqVbcOOJCjC9KOO1 j5UfEsTW2Q31uWY5WXaVz7fx1zBokQFlElFwwIG1sDtY5h8u1E 63KDq_SQzW5SL_FyMkkF9bo_oI5jP7wtpDIgtCeyom1kdl6JSy 1ZGmdlz_tlH1bqDHqEnhOoZifT0PqfoAZs4CT_2oBOG56MYjsl VhcrHM." -
f538ce274d674cf389cb1c41ae6eccac:eeeddd75cd8fe22293815603c6416063 6b7edd91c6f547b4a7d2bddb4fc6e9a0:2f1c3b00902a3df14e6df5d7f0e63972
I mostly need this one, if you don't mind:
https://dashmkpc-vod-aka-canalplus.akamaized.net/mkpc/mvs/canalplay/canalplay.com_122_...m_122_FILM.mpd
https://secure-gen-hapi.canal-plus.com/conso/view/06e0feb0-b87f-11ee;06e0feb0-b87f-11e...fig=mkpl::true
AAAAUHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADAIARIQp8 6T6GjhSHe9pD47n87OcRoIV2lkZXZpbmUiCjE5MTA0MTIwNjJI 49yVmwY=
Hello,
I fail everytime with this one:
AAAAYHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAEAIARIQZ/cRsO5SQQ+/wV1H4EbUwRoIV2lkZXZpbmUiGjAxSE1NMkdYOTExREY0MjdHWF BHV1AzSDlESOPclZsGError message: Error 403: {"status":403,"message":"service MDRM, Getting license impossible : mdrm service temporarily unavailable","code":"MDRM-403-5","params":{"reason":"mdrm service temporarily unavailable"}PASS Token="11101_bwUFkgIe2Fu_p_uFT6ZgCJRa97WzyhNtX2pKi l00JAlYTqQ83svwdHC8OWF86CIFC5HAxiBZPhf_bXf5A5FX-ZBWS8f4ImLW-IFbUKtkJ1uTaweki6jWyyi-ysSyEGqtW5TWBtt5k7gdCP9Ofwt_l0OJx1OGzuF8HvQn67Rpjl SLaScKhKw3J_U9c22HgPvNIN5lXK1MCDi1grwnEr0mwaa8to_x 7BDRN8q9yLlHcY9Uuy1kdC5Iy9VdECxJv2UMgRJIByCclCqZds RK2agEvXNys30JpRhBYodoE7WWx4wOwu-A-A7gwV4Rac8xn5v45XquC9r0xw3aM15Th410TPBVzJ3JdP7Q1zf QafSUPTGYyq8N6d8BNiiojNvcNmt1OE1A7-3_aNae9eUeYcWBAuS3sM6FuBWbqsnou6h9ftsiNQNca7k3_ADk N7puPvZHKEkwh6fUnIN0xx7Xb1vn-JUMOhDZ_8JeVLI5QpDCUpiHg75w1_ijfty8kDiFlQuDoOgJUcm 6a4pH1WYUKQC8JFYTzmZPNsQdylgCsnT91_pANj9pCg3eJyZ3Q FI4QnprYjd7oFYLIrgzo7aAODRatZ0x3RouaskqJf4k-bWxi52boJ3vt4rMt_GCwcCsmMxVaG9DSWPLULxKNTLel0u1db-ursPYYOMH-Bp1k74ESh9krduxWpHQGo0LqB3bRCpaJdhvYXvU3qmz46X0rJu Airx7MKJ5ojqpR_nE_ZC5HkUJKtJDdDXL8JYq2Gkk8sc6xlUWM loL6FsTVpxyUf35ZQXe6UqTLrDcQdwNPG8OS8UBep9Bm0ZNFr-Xkzd9EAUf_guqtcVruUaygMYWfpmnw8BHUJkCOfPmEuhJh77o-Rim6xEYSruY2AHRQZkVOj46Q2ns-hy_fROOed3yOo_HuAUHgBhD5bjTDbdO3Ukr3KLjYlCvray2V3B bnLbbv5Vu0pmbidNpGKA0Bv7gJ3fmB9zn_MLnZk-4RMPRmIj6y44khFeFliHRvpyM9pOaaMYeciDOiYfhTC7H3z4c7 GjgqrGyjuASYjAJap676W7gs4sTOuI03GASSMIj1tDptQoyeSx 2XbiPwAdHlGK4KfbtEXjrfr-f8BYwkWuLlPwd0iVAey-HZHO7zbB6ryiHlKH3Stns9F94SK9ZS0QpZRRcT4DrN55XKTCte DyjAvULhgTruLkMe3JDbEyukDT2BgTMAq4CFxiGkWYUPPspDX4 _uiNxXBIzVUUhatvP_muYKlX6S01Kx8KBjy_Htey70DVRar3M0 PlrfP-UVpf8R6pT0sTSpwDQbRJbFM5wGgoc5qjPTcF8PBCoCwxY6TP1W 3FL3zDvbVExqZHbtswYCyt7Qw6rTu8RouHANymq3Jm_uR8Sgxi IRXoebM_6MafMK9zvRUrD9Hjn1_1D3qJLTs8HmwXr5-JHjDKZiuNJ61FUPLi5dCWogkUsiPF3e0NBEvHks-BW7at8RcqQ8aCC-zk8r2-RYdZ0m3KyewpKaQfP_k."
Can you explain me how to solve this problem please ? -
Hello,
Thanks! I use getwvclone (and http://108.181.133.95:8080/ too).
I need to know how to do that. What did you put in the header please ?
I had no problem with RTBF but fail everytime with MyCanal... -
I ran a python script called "getwvclone" but it only redirects to a local Url so it needs a browser to execute the request. What is your script please?
Hi @ElCap
I'm stuck on the same error as @Tiflo62:
How did you manage to get over it?Code:{ "status": 403, "message": "service MDRM, Getting license impossible : mdrm service temporarily unavailable", "code": "MDRM-403-5", "params": { "reason": "mdrm service temporarily unavailable" } }
I'm using WKS slightly modified to overvome the SSL `DH key too small` error.
I tried with every Widevine PSSH from the MPD.
can somone please help me to download this video from canalplus
By adam2021 in forum Video Streaming DownloadingReplies: 51Last Post: 1st Jul 2025, 10:08 -
Downloading from canalplus.com or france.tv
By pikes6 in forum Video Streaming DownloadingReplies: 7Last Post: 11th Mar 2024, 06:00 -
CanalPlus Keys
By extream87 in forum Video Streaming DownloadingReplies: 1Last Post: 10th Jul 2023, 04:06 -
How to get canalplus.com France Live Channels
By Anonymous149484 in forum Video Streaming DownloadingReplies: 14Last Post: 6th Feb 2022, 12:52 -
How to download videos from Canalplus ?
By ElMagnificato in forum Video Streaming DownloadingReplies: 18Last Post: 12th Dec 2021, 04:58
