What is the best format for subtitles? Also, what would be the best settings for converting pgs files?
[Attachment 76328 - Click to enlarge]
I think there is no "best" format for subtitles. Maybe less or more supported ones. Depends on your goal and player. Often built-in tv players only support srt. All stand-alone mediaplayers I had & have, support internal (stream in sourcefile) SUP (PGS) and srt. Other formats may be supported when external, where ASS-format is a common example.
For srt, players can have several options as to font type/size/colour and positioning (fixed or by honouring tags). For full-HD video and up I edit all my subs and go for 1080p SUP. IMO it's the most supported format where all features are baked-in. It's image-based with format-mandatory positioning, hard for a mediaplayer to go wrong with.
I do add extra srt to important SD video (dvd, old tv-recordings). When viewing SD on a 1080p/4K tv the native subs can come out ugly, sometimes even unwatchable. The images of text based srt will be rendered to output resolution by the player (or tv), looking much sharper. And conveniently, with srt there's no need to deal with different framerates, video-resolutions and display aspect-ratios which SD video comes in.
Not sure what you mean with "converting pgs". PGS to text requires OCR. For which in SE I have "Tesseract 3.02" set. But I think you have to try & find out what works best for you. IMO, OCR will always be subject to reading errors and corrections wil have to be made.
When there's no need to convert to text, note that SE has a so-called "SUP"-editor but it accepts several kinds of sourcefiles (go File --> Import --> Blu-ray (.sup) subtitle for edit). Here you can edit native features like start- & end timestamps, framerate, videoresolution and positionings. It has the same synchronization tool as in text mode and offers basic image manipulations.Last edited by Ennio; 21st Jan 2024 at 04:17.
I think .srt format are the most commonly used one, so that an good choice in itself, but probably there is an other format that might offer some other type of functions or features which make it a lil bit better, then when it come to using the subtitle in reality it might not allso function with all programs and such things!
Making correction during the OCR'ing stage can be time consuming. Let it finish the job, then open the *.srt file in Notepad and make the corrections yourself.
I wonder how batch OCR-ing would work. Every hickup, reading-error or whatever flaw would have to pass, in order to be able to end one process and start the next. Using OCR often myself, I think there'd actually be more work having to check & correct each batch-result, than doing it when live monitoring the OCR process.
"Fix OCR errors" is about replacing "reading errors" with predefined fixes. Which list can be set during installation, but often grows during "learning", where unknown OCR outcomes have to be manually set to a given "fixed" text. I think there never will be a "fix all OCR errors". Reading errors will always be made. Lists will change, or go lost. And are not always proof; they're subject to faulty enterings by human error (typos, misinterpretations, etc). OCR itself actually doesn't know right from wrong.Last edited by Ennio; 22nd Jan 2024 at 07:27.
Need help identifying subtitle format
By treefish in forum SubtitleReplies: 2Last Post: 20th Dec 2023, 14:27 -
Subtitle format with time in brackets
By T0biasCZe in forum SubtitleReplies: 1Last Post: 11th Aug 2022, 05:50 -
TTML2 Subtitle to any Format
By Daringbaaz in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2021, 08:49 -
Bluray Subtitle Format?
By AndersonJames in forum Authoring (Blu-ray)Replies: 5Last Post: 19th Oct 2020, 00:32 -
TextST subtitle format?
By casv in forum SubtitleReplies: 3Last Post: 12th Oct 2019, 06:24
