What are some frame-by-frame video cutters that support and keep subtitles after cutting, and can encode them to lossless video codecs?
Results 1 to 27 of 27
As far as I know, all but one form of subtitling must be edited separately from the video and audio using a subtitle editor. EIA-608 closed captioning (used in North America and (I think) Korea) is the one exception I am aware of, and most video editing software strips them when exporting the edited video. The only video editors I have used that preserve them are VideoReDo (no longer available for sale) and TS-Doctor (only for editing video and audio in a TS container).
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Can mpv and ffmpeg do it, then? How do you get a video preview for the latter while doing it?
Strictly speaking the subtitles can be soft or hard embedded. Which type is it?
Does your program work for pgs subtitles? Can it cut videos frame by frame? Does it have a video preview?
There are no video editors that can cut PGS subtitles that I know of.
I haven't tried cutting PGS subs myself but I seem to remember a thread that said it can be done with Subtitle Edit. However, I think subtitles have to be demultiplexed first.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
You can use clever FFmpeg-GUI for cutting and preserve all embedded subtitles, but on keyframes only.
The cut is done with streamcopy, so no reencode is done. -
You can preview while searching the keyframes.
You can also watch the video in any player and make a note of the desired cut times.
clever FFmpeg-GUI then searches for the closest keyframes and cuts to them.
The cut is fast because it is done with streamcopy. -
Accurate cutting and lossless cutting are two different things. As I said before, clever FFmpeg-GUI can cut on keyframes lossless that it runs as streamcopy.
But something else.
You ask and ask and ask, I won't answer you anymore unless you ask for a well-defined problem. -
All right, how about this? I originally wanted to burn in pgs subtitles, but I realized that .ass is better so I decided to convert them and then burn them in using Avidemux. Now how do I use the tool to split my video into multiple fragments, and save one selection as an image sequence of png files?
Solveig Video Splitter can do this (been doing it for years with H264/SRT in MKV). Unfortunately it has now gone subscription only which makes it a bit pricey for occasional use so I stick with the old version I purchased some time ago. Does frame accurate cutting encoding only the balance of cut I frames which makes it fast.
HTH
Chris K -
Not on their current codec list (H265/HEVC, H264/AVC, MPEG-1, MPEG-2, MPEG-4, DIVX, XVID, MJPEG, WMV1, WMV2, WMV3, MPEG Audio, PCM, AC3, AAC).
Have you tried Lossless Cut? This uses FFMPEG as the engine and claims 'Experimental Smart Cutting' though I could never get that to work. That certainly keeps subtitles when cutting TS files, YMMV.
Chris K -
Can Solveig Video Splitter encode videos to any lossless format, or no?
Regards,
Dmitry | SolveigMM | Smart Video Editing (H624/MPEG-2/...)
Avidemux cutting
By techmot in forum EditingReplies: 7Last Post: 11th Aug 2023, 13:10 -
MX Player Subtitles Settings not working on videos with SSA subtitles
By anubhav007 in forum Newbie / General discussionsReplies: 0Last Post: 14th Jun 2023, 05:07 -
Cutting uhd files
By Travillion in forum EditingReplies: 10Last Post: 20th Nov 2021, 05:09 -
How to convert mkv (with subtitles) -> mp4 (with subtitles)
By covo in forum Video ConversionReplies: 4Last Post: 18th Oct 2021, 11:42 -
Insert Forced subtitles in Original subtitles (.srt)
By VideoOn in forum EditingReplies: 1Last Post: 12th Feb 2020, 01:43
