Results 1 to 11 of 11
  1. Banned
    Oct 2023
    Los Angeles
    I found out that Shotcut can make webp files from YUV videos, but are they lossless? Also, I found that Kdenlive also had that option, but I can't use it. How do I fix that?
    As a side note, how do I make export image sequence from the two programs go faster?
  2. You can add custom export profiles to shotcut - but shotcut for certain is not lossless for 10bit video input because of the processing
    Shotcut has an 8bit timeline. A 10bit YUV video will not be properly processed because the 10bit YUV will be truncated to 8bit YUV first. Even an 8bit "lossless" PNG or webp export will have losses compared to a proper workflow because of the loss of precision upstream.
    Not sure about kdenlive
    To make something go faster, use a lower compression setting if possible, use multiple instances if possible, or get a faster computer. There is no other way
  3. Banned
    Oct 2023
    Los Angeles
    I get it now. Kdenlive said this:
    [Attachment 76315 - Click to enlarge]
  4. kdenlive apparently support 10bit
    https://www.omgubuntu.co.uk/2022/05/open-source-video-editor-kdenlive-gains-10-bit-color-support
    But when I tested it, the 10bitYUV conversion to 8bit RGB such as PNG has slight +/- 2 errors - so it probably means you can import/export 10bit , but it's not proper support and will have rounding errors
    shotcut and kdenlive use MLT framework , here is the TODO list:
    https://www.mltframework.org/changes/todo/
    and the 8.x(next) branch in the future
    a new image processing framework that:
    supports 10-bit input and output (future support for 12-bit desired)
    supports HDR (HDR10/PQ, HLG)
    maximizes usage of multi-core CPU and GPU
    ensures scene-referred linear color image processing
    compatible with avfilter, OpenCV, and Qt high bit depth
    So they are not fully ready for 10bit processing yet
  5. Banned
    Oct 2023
    Los Angeles
    So it's not lossless for both png and webp files?
  6. Originally Posted by Jay123210599 View Post
    They are no lossless for the compression step if done properly. (Shotcut should be for webp if you used a custom profile with lossless=1, but I didn't verify)
    But results are not lossless for >8bit video input because of the 8bit intermediate step
    (As explained in your other threads, integer RGB will always be lossy for YUV video (you can never get back the original YUV values), but there is an "Expected result" for a RGB conversion . The results for kdenlive deviated more than the expected result - likely from the 8bit intermediate step)
    You should verify for yourself if something is lossless, and not just the compression.
    Even if the compression step is lossless, the program or workflow might have other processing errors upstream or downstream that would make the end result not lossless. Methods to check "lossless" were posted in your other threads .
    Even if the export is verified as lossless, it doesn't mean the handling downstream will be lossless by other programs. For example some browsers and programs and PNG's with gAMA and cHRM tags - they will be displayed with different color. Another common example is certain "lossless" formats are not handled as "lossless" by some video editors - they are mishandled and undergo other colorspace . conversions. Another example is errors in conversions such as wrong matrix - you experienced that in your other thread
  7. Banned
    Oct 2023
    Los Angeles
    But using ffmpeg would be better than using Shotcut and/or Kdenlive?
  8. Originally Posted by Jay123210599 View Post
    Yes, because it supports 10bit YUV input properly
    But you must still do the other steps like YUV =>RGB conversions properly, possibly with matrix/transfer/primaries/range. There are many potential issues depending on the input video, export format , as already mentioned in your other threads. You've seen firsthand different colors because of wrong processing, wrong switches - ideally ffmpeg would do everything correctly automatically; but a ffmpeg developer would call that "user error".
  9. Shotcut Lead Developer
    Jun 2015
    California
    That is not correct. As of version 23.05, if you turn on Settings > GPU Effects it can support a 10-bit pipeline. From the release notes:
    >End-to-end support for 10-bit! For this to work, on 10-bit sources use only GPU filters. Nothing prevents you from adding CPU filters, but that will introduce an 8-bit down- and up-conversion into the pipeline.
    That linked article and others was over-hyped from a MLT release note: "Fixed full range 10-bit video input in avformat producer."
    It could always read broadcast limited 10-bit and down-convert to 8-bit, but the key words there are "fixed full range." It took additional work to extend 10-bit to the GPU (OpenGL) effects engine named Movit integrated into MLT: "Added 10-bit video support to movit.convert filter." Movit converts inputs to uses 16-bit float textures with linear color.
    You also need to be careful about your export, and for that Shotcut has a category of export presets named "ten_bit".
    I do not know why you brought this up when the poster was only asking about WebP output, but someone needs to correct you.
  10. Originally Posted by ddennedy View Post
    Nice, thanks for the correction and updated info
    There is some prior posting history of the OP that you are not aware of ...
  11. Banned
    Oct 2023
    Los Angeles
    But using ffmpeg would still be better?
