Hello,
I have a video file I have been scratching my head on how to deinterlace. It has been a total pain in the butt to figure this out. I don't know if its IVTC'd or interlaced. The frame order goes: INT, INT, PROG, PROG, PROG, INT, INT then repeats. If anyone could figure this out, that would be great. I tried TFM(order=1) but the results are still not extremely clean.
Sample can be found here: https://mega.nz/file/oOwxWDzD#tUL51ln78c43TsIy8o6tfODssbG-m5kwV963KdYDQoM
Thanks![]()
Results 1 to 17 of 17
just for fun (not using Avisynth): https://imgsli.com/MjM0Njc4
TIVTC + CAS+ FeMaSR seems a bit too much sharpening (script).
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
I will post it in a moment, I have to get on my main PC to pull the script and get the sample out. For now, I want to leave you guys with two more clips. There are some very obvious edits here and there from the original edit and I want to see how you guys tackle it. It looks like the footage is also sped up(?) which is why I want to leave the framerate at 29.97... Clips are below:
Clip 1
Clip 2 -
To me, TIVTC seems to work fine for those two. (maybe add some aa afterward, to remove some aliasing in some frames)
just for fun:https://imgsli.com/MjM0ODMx/users currently on my ignore list: deadrats, Stears555, marcorocchini -
You don't want to leave the frame rate at 29.97 fps. It's telecined film (24 fps film, with most character animation at 12 fps, panning at 24 fps) so you want 23.976 fps. The result will be the same running time. Simple TFM().TDecimate() as in post #2:
videotapeedit1.mov has some VFR (variable frame rate) content. There are sections with 29.97p content and 11.988p content. The problem if you leave it at 29.97 CFR is the 23.976 sections have jerky stutter at 29.97 since you have a duplicate every 4th, 5th frame. If you make it 23.976 CFR, then you lose some unique animation frames. I suspect 99% of the content will be 23.976, and most people would leave it at 23.976 for ease of use . Some people would leave it bobbed at 59.94p but that would slightly degrade most of the frames. Others would leave it interlaced and let the display handle it (and that depends on how the display handles it - it varies between hardware, most would probably deinterlace)
You'd have to make it VFR to have each section play at the correct speed. But 23.976 sections will show "normal" judder on a 60Hz display, and everything should be perfect on a judderless display (e.g. 120Hz or similar) -
Yes, upon looking more closely there are some 29.97p sequences too. You can use TFM() to bob the video to 59.94 fps.
Code:function TFMBob(clip v, int "pp", int "cthresh", int "MI") { pp = default(pp, 6) cthresh=default(cthresh, 9) MI = default(MI, 80) v.GetParity() ? Interleave(TFM(v, field=1, pp=pp, cthresh=cthresh, MI=MI), TFM(v, field=0, pp=pp, cthresh=cthresh, MI=MI)) : Interleave(TFM(v, field=0, pp=pp, MI=MI), TFM(v, field=1, pp=pp, cthresh=cthresh, MI=MI)) } v1 = LWLibavVideoSource("videotapeedit1.mov", cache=false, prefer_hw=2) v2 = LWLibavVideoSource("videotapeedit2.mov", cache=false, prefer_hw=2) v1++v2 TFMBob() ConvertBits(8)
Alright, I think having the frame rate be at 59.94 FPS is an okay compromise, but it would increase the file size. If it means the content is properly archived then I am okay with that.
Also, I wasn't able to go on my main PC last night. I do know that the script I used is literally just the source file, then TFM(order=1) with nothing else after it. I am still new to avisynth and what you guys have done so far is further ahead than anything I could do to the file...Last edited by bit.whisperer; 23rd Jan 2024 at 14:49. Reason: spelling and I typed the wrong frame rate
My other concern is that the credit fades at the very end of this file are in 29.97fps. Are the solutions that are currently being shown here would account for that? I was just going to fix it in editing where I would just remake the fade in and outs.
Not by much if you use the right encoder. Most of the extra frames will be near duplicates (just minor encoder artifacts). Duplicates don't require much bitrate. You could even use a filter like Dup() to replace the near duplicates with exact duplicates making them take even less bitrate. Also, some encoders that support Constant Rate Factor encoding (x264 and x265) are frame rate aware. They understand that minor artifacts that flash by at 60 fps are less visible than the same artifacts plodding by at lower frame rates. So they use less bitrate per frame at higher bitrates.
For example, using TFM() instead of TFMBob() (30 fps vs 60 fps) with the x264 encoder with the slow preset at CRF 18 changed the overall bitrate by only about 1 percent.Last edited by jagabo; 23rd Jan 2024 at 10:00.
Do you have any ffmpeg params I should use? Currently I am using this:
Code:ffmpeg -y -i "MASTERED.avi" -map 0:0 -c:v libx265 -preset slow -b:v 10000k -threads 16 -aspect 4:3 -x265-params pass=1 -f mp4 NUL && ffmpeg -i "MASTERED.avi" -map 0:0 -c:v libx265 -preset slow -b:v 10000k -x265-params pass=2 "video.mkv"
Bitrate based encoding is really only for when you need a file of a specific size. If you want to be assured of quality use crf encoding. Otherwise x265 with the slow preset should give decent results. Experiment with a few different crf values (16 to 25?) and decide which values gives you the quality you want. Then encode all your videos with that crf.
Deinterlacing DVD source while preserving the maximum quality possible.
By dopethrone in forum Newbie / General discussionsReplies: 24Last Post: 19th Feb 2022, 23:54 -
Bob deinterlacing in AviSynth without doubling the frame-rate?
By orion44 in forum Video ConversionReplies: 11Last Post: 6th Dec 2021, 00:44 -
AviSynth Script for Only Deinterlacing Combed Lines (MeGUI)
By AOmundson in forum Video ConversionReplies: 9Last Post: 15th Mar 2021, 14:04 -
Best AVISynth+ settings for deinterlacing these DVDs?
By Xandros in forum Video ConversionReplies: 2Last Post: 15th Jun 2020, 03:34 -
Encoding, Deinterlacing, and Denoising with AviSynth+
By SamFinisher in forum Newbie / General discussionsReplies: 14Last Post: 26th Jan 2019, 23:05
