How do I change the dpi when making images with ffmpeg? Will it lower the quality of the images?
Oh, and by the way, for webp files, do -lossless 0 and -lossless 1 both make lossless results or only the latter can?
Results 1 to 15 of 15
Pixels have no physical dimension, DPI is just meta data used to give them a default physical size when you have a physical canvas. If you have a 300px*300px image using 72DPI and change just the DPI it's still a 300px*300px image, it's the exact same image data.
If you were to display these images in web browser and don't specify a size with HTML it uses the native pixel size, they would display exactly the same each taking up an area 300px*300px on your screen because a browser doesn't use DPI. Insert these two images into a Word document which has a physical canvas and they will be different sizes. -
Video screen cannot squeeze pixels as we wish. DPI does not apply. If we watch video/images, they get resized - either upscaled (so new pixels are interpolated/created) or downscales (less pixels is generated/interpolated) when watching it to fit your monitor/TV/viewing area.
Almost every time you pull an image or video on screen using your PC player or web browser, it always resizes an image to your viewing area. You drag the corner of your video player or your browser, video/image gets constantly resized to fit your monitor area. You rarely see a content scaled exactly as 1:1, as you encoded.
In some lucky moment or when watching specific content, like Blu-ray that has 1920x1080 resolution and watching it on full screen that has 1920x1080 resolution, you see pixels 1:1, as they were encoded. Or If you have a player and say 1280x720 video and you specify in settings of player (or click a dedicated button) to show 1:1, you get again original pixels on screen.
That is why you are constantly bombarded with question what your intentions are with those images, what it is for. Because for example, as integrating images to a web page, you do not want to have images of large proportions squeezed to a lesser resolution (space that it has available on web page), because your increase web traffic and everything is slower. Your large image would be viewed as much smaller resized resolution anyway. For web, you try to integrate images with just a right/smaller resolution so it is ok for a web page to just fit and most certainly it would be jpg or something compressed. Photoshop has a feature for that, like optimizing jpg etc. , I forgot how it was called. For download on the other hand, you might offer a means how to get a full blown up image or sequences of images. But sequence of image as download makes little sense also, you are better off having available a compressed video sequence.
Cartoons are compressible many many times better as video as oppose to separate images. 10 times fold at least? I'd say even more. Try to compress cartoon with high resolution, good quality and then calculate size per frame, you will be stunned comparing it to sizes of your standalone png's. -
Well, the reason I want to make images sequences so I can manually select the best images to upload to DeviantArt. Since my videos are 10bit, how do I extract them as 10bit images? Do those types of images even exist?
Why would you extract all of them , if you're only going to upload a few? - seems like an enormous waste of time
Why not choose the few you are going upload in a media player, or vdub2 then export those?
10Bit RGB images exist (e.g. DPX) - it's a very common format in films for production work - but nobody on DeviantArt will be able to see them . There is no browser support. Even if there was hypothetical browser support , it still wouldn't work, because DA wouldn't accept them
Look at the DeviantArt supported files
https://www.deviantartsupport.com/en/article/what-file-types-can-i-submit-to-deviantart
For images, you have 3 choices
Images: JPEG, PNG, GIF -
Well, I used both ffmpeg and shutter encoder to make dpx and they both resulted in images that were 30bit. Do other file formats for 10bit images exist? Or am I doing something wrong?
Resolution is measured solely in pixels.
DPI only affects the display size (think, zoom), whether electronic or paper. It also has nothing to do with quality, although human sensitivity to sharpness is a combination of rez, dpi/zoom level, contrast & distance (and individual sensitivity.
I'll let someone else talk webp since I almost never use them.
<Edit>doh! this got stuck and didn't send for an hour...
ScottLast edited by Cornucopia; 20th Jan 2024 at 01:05.
Also, (continuing on what was said), as previously mentioned, 99% of viewers will be viewing the images on an 8bit/24bit monitor or TV, so for them, you gain nothing by having your posted copies at 10bit/30bit. Nothing.
(You MAY gain something if your intermediate format is higher bit and you do processing, because this reduces or avoids banding, but that is only true if the bitdepth reduction step at the end is done correctly, and the step may itself be considered lossy).
Scott -
If you are changing just the DPI at the very most it might change by a byte or two, there is no change in the image data. The discrepancy would be because of changes to the header.
Here is some examples. The image data is identical. Save the files and import into Word doc to see DPI in action.
249x276 @72 DPI
249x276 @600 DPI
Scene change
By coolgit in forum RestorationReplies: 6Last Post: 9th Oct 2021, 13:22 -
TIFFs with no DPI when extracted from video
By taigi in forum RestorationReplies: 3Last Post: 21st May 2021, 00:40 -
change framerate
By christophe195 in forum Newbie / General discussionsReplies: 6Last Post: 31st May 2020, 14:16 -
Should i change my VCR?
By patters1978 in forum Capturing and VCRReplies: 41Last Post: 1st Feb 2020, 00:42 -
Is there a way to change my username here?
By davevid in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2019, 15:14
