I haven't messed around with bluray copying in a number of years but I have several blurays that I'd like to have the encryption removed to where I can make a one-to-one full copy of the entire bluray to another blank bluray disc.
I already have software to copy the bluray discs or to burn a bluray from an ISO file. My only concern/need at this point is the encryption removal.
Any suggestions are greatly appreciated.
It doesn't look though like the MakeMKV program allows for an exact duplication of the bluray onto a new/empty bluray, right? I'm not wanting to just extract the files/clips off of a bluray to play... I'm desiring for the encryption that's part of most blurays to be removed to where I can literally make an exact copy of the bluray onto a new/empty bluray. I've got an extensive bluray collection and am wanting to take some time to make 1:1 full copies of each bluray to have as backups in the event the original blurays become damaged and unplayable.
Is Cinavia still an issue for all of them? Me too, haven't done this task for few years. The way I use to do it is have Slysoft running in the background and use IMGBurn to make an exact disc image of the disc content with all protections disabled, then copy the protection-free disc image back into a BD-R with the same size, Cinavia was never resolved back then, but only few discs had it.
MakeMKV can be set up to both decrypt and copy files and folders from the Blu-ray to an HDD. If that succeeds, then the files and folders can be burned to BD+R DL media (most commercial Blu-ray releases are too large for BD-R) using ImgBurn or other similar software.
However, MakeMKV doesn't remove Cinavia if it is present. As I recall Slysoft's software doesn't remove it either but prevents it from being detected by software players that look for Cinavia.
[Edit]As I recall, when Cinavia is actually removed, the resulting audio sounds different and it's an unpleasant effect. I think that one of the Cinnavia removal software solutions finds a source for audio tracks that don't have Cinavia and substitutes them.Last edited by usually_quiet; 19th Jan 2024 at 12:55.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
dvdfab has a tool to remove cinavia - https://www.dvdfab.cn/dvd-cinavia-removal.htm?trackid=headmenu2
there is a list of titles that have been repaired - https://blog.dvdfab.cn/cinavia-protection.html
just click under "reference lists" the titles highlighted in green are the ones than have been repaired.
Linux full ffmpeg x264 bash script for quick & dirty & fast video encoding
By M.Shiver in forum LinuxReplies: 16Last Post: 6th Nov 2023, 11:30 -
Remove region lock from UHD Bluray disc
By kallek in forum Blu-ray RippingReplies: 7Last Post: 9th Oct 2023, 10:24 -
Full Bluray 3D ISO to 1:1 copy to mkv
By smounche in forum Blu-ray RippingReplies: 16Last Post: 15th May 2023, 14:00 -
4K MOV File to Bluray Disc
By techguy817 in forum Newbie / General discussionsReplies: 4Last Post: 27th Jan 2022, 14:08 -
bluray disc from folder to iso And a picture in the virtual disc icon
By CapricornX10X in forum Blu-ray RippingReplies: 3Last Post: 27th Jan 2020, 13:01
