Closed Thread
Results 1 to 11 of 11
  1. Banned
    Oct 2023
    Los Angeles
    Which tool or programs produces the best visually lossless jpgs that match the color of the input video with the highest quality in the smallest file sizes?
  2. Member Cornucopia's Avatar
    Sure would help if you ACTUALLY told us the use case for this, instead of creating yet another topic.
  3. Banned
    Oct 2023
    Los Angeles
    To post the files to DeviantArt, of course. Can you answer this question?
    https://forum.videohelp.com/threads/413081-Best-Image-Compressor
  4. Banned
    Oct 2023
    Los Angeles
    That doesn't answer either of my questions.
  5. Banned
    Oct 2023
    Los Angeles
    Which file format is the least lossy for YUV videos, jpgs, lossless webps, or regular webps?
  6. Member Cornucopia's Avatar
    They have already been answered.
    "Visually lossless" is in the eye of the beholder (you, and your target audience).
    For png, you have already been recommended pngcrush.
    For jpg, a simple Google search of "jpg optimize" yields a bunch which are reasonable - try them yourself to see which you like.
    If it still isn't small enough for your taste, you will have to compromise on the resolution or the quality or both, as we have told you before.
  7. Member Cornucopia's Avatar
    Already asked & answered by jagabo & pdr.
    You must separate the idea of loss due to color system change and loss due to compression, and work to independently optimize them.
  8. Banned
    Oct 2023
    Los Angeles
    Can pngcrush optimize multiple images at once?
  9. Member Cornucopia's Avatar
    Pngcrush is a commandline app. You can easily create a batch script using "for...".
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    PLEASE STOP several similar threads.
