Hi. I'm having issues selecting what audio channels are being monitored. When I press the Monitor Select button and then channels 1 or 2, nothing changes -- they are stuck on 3 & 4. Because of this, when I'm digitizing a tape that has only 1&2 audio, I cannot monitor with headphones or the XLR Monitor Ouput on the back. Any advice? I noticed that when I ejected a beta tape, the deck auto switched to monitoring 1&2. I put the tape back in and it switches to 3&4.
Thanks for any help.
Jare
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
It may have another menu screen where you can turn on and off which channels to toggle for monitoring, If I was you I would go through the entire user manual to find out.
Need a little help using Sony DSR-1500A deck to capture MiniDV videotape
By NY2LA in forum CapturingReplies: 5Last Post: 3rd Feb 2023, 15:53 -
Sony SL-HF2000 Super Betamax deck model?
By jham55 in forum Newbie / General discussionsReplies: 0Last Post: 2nd Feb 2023, 13:50 -
Sony EV-C200 Hi-8 VCR deck will not play tapes
By Selcouth in forum Newbie / General discussionsReplies: 1Last Post: 20th Feb 2022, 10:06 -
SONY DVW-500 and 500p - issues with 2 PAL tapes
By MikeMGMVE in forum Newbie / General discussionsReplies: 6Last Post: 11th Sep 2020, 02:46 -
ED Beta Metal tape in a Regular Beta VCR ? Does it work?
By Tom81 in forum MediaReplies: 1Last Post: 4th Mar 2020, 01:55
