Hi, guys!
I'm trying to download video from iframe.mediadelivery.net with streamlink
but have this errorCode:streamlink --http-header User-Agent="Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36" --http-header Referer="https://iframe.mediadelivery.net/embed/195537/3c65fdd1-af96-449d-8b1c-bd21cce44027" "hls://https://iframe.mediadelivery.net/3c65fdd1-af96-449d-8b1c-bd21cce44027/playlist.drm?contextId=9c25c1ca-f4f2-40b7-aba7-b16f2d666a6a&secret=175d57e0-a57e-4ae6-922c-4ed25119bd43" best -o "C:\Users\MyProfile\Downloads\video.ts"
Video urls:Code:[cli][info] Found matching plugin hls for URL hls://https://iframe.mediadelivery.net/3c65fdd1-af96-449d-8b1c-bd21cce44027/playlist.drm?contextId=9c25c1ca-f4f2-40b7-aba7-b16f2d666a6a&secret=175d57e0-a57e-4ae6-922c-4ed25119bd43 error: Unable to open URL: https://iframe.mediadelivery.net/3c65fdd1-af96-449d-8b1c-bd21cce44027/playlist.drm?contextId=9c25c1ca-f4f2-40b7-aba7-b16f2d666a6a&secret=175d57e0-a57e-4ae6-922c-4ed25119bd43 (401 Client Error: Unauthorized for url: https://iframe.mediadelivery.net/3c65fdd1-af96-449d-8b1c-bd21cce44027/playlist.drm?contextId=9c25c1ca-f4f2-40b7-aba7-b16f2d666a6a&secret=175d57e0-a57e-4ae6-922c-4ed25119bd43)
https://piclub.in.ua/polza/video12
https://iframe.mediadelivery.net/3c65fdd1-af96-449d-8b1c-bd21cce44027/playlist.drm?con...c-4ed25119bd43
Please help to download this video. Maybe there are other ways or I'm doing something wrong![]()
Closed Thread
Results 1 to 30 of 44
yt-dlp + custom python script. More explained here: https://forum.videohelp.com/threads/411645-Trying-to-download-from-iframe-mediadelivery#post_2706217
I downloaded it using that script and it works.
Code:if __name__ == '__main__': video = BunnyVideoDRM( # insert the referer between the quotes below (address of your webpage) referer='https://piclub.in.ua/polza/video12', # paste your embed link embed_url='https://iframe.mediadelivery.net/embed/195537/3c65fdd1-af96-449d-8b1c-bd21cce44027', # you can override file name, no extension name="test_name", # you can override download path path=r"test_path") # video.session.close() video.download()
simply py script with embed url
[Attachment 76267 - Click to enlarge]
[Attachment 76268 - Click to enlarge]
Hi, guys!
I'm trying to download another video from iframe.mediadelivery.net with yt-dlp + custom script from https://github.com/MaZED-UP/bunny-cdn-drm-video-dl
This method works fine for video from link
But for video
https://piclub.in.ua/polza/video15
https://iframe.mediadelivery.net/embed/197153/b691fe45-7da0-4587-b8b0-a918bd04210b
it's now working.
Show this error message
user@user Downloads % python3 b-cdn-drm-vod-dl.py
File "/Users/user/Downloads/b-cdn-drm-vod-dl.py", line 178, in <module>
File "/Users/user/Downloads/b-cdn-drm-vod-dl.py", line 84, in __init__
self.context_id, self.secret = search.group(1), search.group(2)
AttributeError: 'NoneType' object has no attribute 'group'
Help me please to download this video. Maybe there are other ways :/
Just copy the command directly from the stream detector addon. This one doesn't need a pinging script.
N_m3u8DL-RE -M format=mkv --header "Referer: https://iframe.mediadelivery.net/" --key 24ed4d377b815ba6b0eec470db39a02f:54fa182f9e9e4d4408e4bd6a4a310377 --key 3754ee42388851a39e4d2d17adfc7905:1473cd625493e4f079c09902ac408c41 --key 86d2d142ff905d4fa4060aec0d262990:206f9999121ef9965c945a9002422ef8 "https://vz-721f5576-1eb.b-cdn.net/b691fe45-7da0-4587-b8b0-a918bd04210b/playlist.m3u8" --save-name video
Thank you, iamghost! It's work for me!
I can found one part of keys in "stream_*.m3u8" files by "KEYID=..." but can't find second part.
Example:
24ed4d377b815ba6b0eec470db39a02f:54fa182f9e9e4d440 8e4bd6a4a310377
can find: 24ed4d377b815ba6b0eec470db39a02f
but can't find: 54fa182f9e9e4d4408e4bd6a4a310377
Please tell me more detailed how you searched keys?
use
https://cdrm-project.com/
add pssh and lic url thats all you need
[Attachment 76386 - Click to enlarge]
By using the laziest possible approach. Stream detector addon --> select m3u8 (playlist in this case) --> copy as yt-dlp/n_m3udl-re/whatever command --> paste in cmd and run.
The download command is (simplified to keep only relevant data):
Code:N_m3u8DL-RE "https://vz-75184480-b28.b-cdn.net/219ad942-8568-4512-bd86-fcff74346227/playlist.m3u8" --header "Referer: https://iframe.mediadelivery.net/"
Video URL?
Video URL?
OK, working now with the BunnyVideoDRM python script.
I used wrong url, I used playlist urlCode:https://iframe.mediadelivery.net/fd8525a7-6dc1-44ae-a05a-215583bc6985/playlist.drm?contextId=b95b5210-8935-418b-b714-caf165c232a6&secret=d96d0971-6485-424a-8393-b7f071abec71
Code:https://iframe.mediadelivery.net/embed/43012/fd8525a7-6dc1-44ae-a05a-215583bc6985
I've used yt-dlp to download much larger files from other sites, and merging files was always quite fast.
Can anyone help me figure out how to download videos? I've been trying the custom python script but nothing is happening:
Code:if __name__ == '__main__': video = BunnyVideoDRM( # insert the referer between the quotes below (address of your webpage) referer='https://courses.jsmastery.pro/course/ultimate-nextjs/001_intro-prerequisites/001_intro', # paste your embed link embed_url='https://iframe.mediadelivery.net/embed/239225/af00dc86-fad0-4264-be9a-817d9051adf7', # you can override file name, no extension name="", # you can override download path path=r"") # video.session.close() video.download()
Hello, Im trying to download the video from https://laalquimica.com/masterclass-9-de-noviembre-2024/
it creates a bunch of links iframe.mediadelivery....
Tried with the stream detector + yt-dlp method but cannot make it work.
Can someone help me?
I really wanted to figure this myself but i tried as best i can and ran outta luck. I understand maybe half of the discussion on how things work so be patient with me. I need to download this video and im stuck.
https://iframe.mediadelivery.net/play/244546/d01e45c8-2545-4cb3-b69a-927f8e6c065d
And yes, i know.. the video is... something
The only progress i got so far is getting a very streamedlined build of yt-dlp and i followed a tutorial here:
https://www.youtube.com/watch?v=nAeNApj0WGw
And this didn't worked
Download from iframe.mediadelivery.net
By andreww in forum Video Streaming DownloadingReplies: 13Last Post: 19th Dec 2023, 15:55 -
Download from iframe.mediadelivery.net returns me Unauthorized
By devtanya in forum Video Streaming DownloadingReplies: 2Last Post: 12th Dec 2023, 08:26 -
By AceOne in forum Video Streaming DownloadingReplies: 1Last Post: 30th Sep 2023, 18:08 -
iframe.mediadelivery.net gives me 401 Unauthorized
By Anonymous84734 in forum Video Streaming DownloadingReplies: 8Last Post: 18th Sep 2023, 11:15 -
Help to download from iframe.mediadelivery.net
By safinok in forum Video Streaming DownloadingReplies: 1Last Post: 5th Apr 2023, 00:03
