Hi,
I've a video media file and "mediainfo" shows it has QuickTime TC subtitles. However I don't see the subtitles while playing the video in MPC-HC/BE, VLC.
Not sure if the subtitles are indeed in there or not. How do I confirm that?
Please advse,
General
Complete name : video.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 4.15 GiB
Duration : 1 h 28 min
Overall bit rate : 6 709 kb/s
Frame rate : 50.000 FPS
Writing application : Lavf58.5.100
Video
Format : AVC
Format profile : High@L5.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Format settings, GOP : M=4, N=25
Codec ID : avc1
Bit rate : 6 500 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.063
Stream size : 4.05 GiB (97%)
Writing library : x264 core 149 r2802M 8c29742
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=24 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=25 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc_lookahead=25 / rc=abr / mbtree=1 / bitrate=6500 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Constant
Bit rate : 160 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 101 MiB (2%)
Default : Yes
Alternate group : 1
Other
Type : Time code
Format : QuickTime TC
Language : English
Default : No
Timecode != subtitles.
I don't know what app will show TC other than QT player itself.
Scott -
It is NOT a subtitle track. It is a timecode track. (As Cornucopia said.)
The timecode will show up in the counter of the quicktime player, not superimposed over the image.
I haven't used quicktime player in years -- but I recall you can switch the counter display to either runtime or timecode.
The "big" NLEs -- Premiere, Resolve, Avid and Vegas can also read QT timecode tracks.
Also, timecode tracks usually give a start time, so yours may be empty anyway. -
Maybe the 'MediaLooks QuickTime Source DirectShow Filter' can help out, it is supposed to function together with other media players allso if quicktime player 7.7 is installed together with the MediaLooks QuickTime Filter. From the info found one of the features is to read QuickTime Time Codes (TC), maybe then it will function with the Media Player Classic allso!.
QuickTime Movie question
By Daniyar in forum Newbie / General discussionsReplies: 10Last Post: 27th Aug 2023, 10:10 -
Video Levels in Quicktime
By GaneshRavi1125 in forum Newbie / General discussionsReplies: 8Last Post: 4th Jan 2022, 10:04 -
.MOV with QUICKTIME 4 on OS 8.6 iMac G3
By mr_fede in forum MacReplies: 1Last Post: 29th Oct 2021, 13:44 -
How to record the audio in a video using Quicktime or any other?
By mikehende in forum MacReplies: 1Last Post: 24th Mar 2021, 14:05 -
Using Windows' QuickTime 7 Encoders without QuickTime?
By cke in forum MacReplies: 11Last Post: 23rd Jun 2020, 10:10
