We would like to make an mp4 that contains highlights from 13 years of video we took of our family mostly focused on our children.
I converted everything to mp4 and have it all on a hard drive as well as a usb drive.
My wife wants to decide what goes into the final movie but she is not very technical. I am thinking of having her go through all the mp4s and write down the time stamps where she wants me to use footage. Then I can take her notes and put it together using some video editing software.
I used Moavi to video converter to convert everything I captured to mp4 so I was thinking of using their editing software but I haven't tried it yet.
I would appreciate any suggestions for an easy to use video editing software for Windows 11 that I can use to easily select portions of the clips on a timeline and also add music.
Also any general tips on things to avoid, things to do, that type of thing. I am new to this but I have done some simple video editing prior to this project.
Thanks in advance.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
There are so many video editors available today I can't really tell you what is best for you to use.
You can try DaVinci Resolve the free version for example.
Magix has a lot of video editors and they offer a lot of deals with discounts if you give them your email address when you try any of the video editors with free trials.
What I can suggest after you have a final video (hopefully NOT on a DVD or Blu-Ray) is to add subtitles of the dialogues in those videos. It is a big help to HOH people and children to understand better what is being said.
Advice needed on best format to use please
By dazzystar in forum Video ConversionReplies: 2Last Post: 15th Oct 2022, 22:06 -
help needed-project ending with errors
By tyson25 in forum Authoring (DVD)Replies: 5Last Post: 19th Jul 2022, 15:07 -
Advice needed in digitizing/restoration/cataloguing project
By crbd98 in forum RestorationReplies: 4Last Post: 10th Mar 2021, 23:48 -
Need urgent advice on Vegas DVD architect project
By voodoosushi in forum Authoring (DVD)Replies: 6Last Post: 2nd Sep 2019, 09:52 -
Betacam Component Capture advice needed.
By Gibson767 in forum Capturing and VCRReplies: 13Last Post: 19th Aug 2019, 21:34
