Hi does anyone know why my two external HDDs willl often (at random times) keep disconnecting from the USB ports they are plugged into on my Lenovo laptop?. I have them both connected via a cheap USB hub so maybe the issue is with that, but I don't think that's the cause. My sons new gaming PC seems to do the same with USB keyboard, even though it's connected by one of the many ports (some are on the back and some are located on the top of the base unit tower - no idea why they've installed ports there for) and after booting Windows up I often find that the keys won't work and that I need to unplug the UBS cable and plug it back in to get the keyboard to function. Also, like my Lenovo it will sometimes unplug other connected devices such as a gaming control with the "disconnect/connect" sound being heard. This seems to be a real pain. I've never had this issue on any of my older laptops or my desktop PC, it's only since using Wndows 11 I this problem seems to be happening. Could be down to the wrong USB type or cheap cable.
Power management on HDD and perhaps on USB port? Insufficient power on USB port? Poor mechanical connector? There can be many reasons...
So when you're sitting at your desk and want to connect: analogue digitiser, scanner, camera, external HDD or phone, you can do so easily, without getting down on your hands and knees to scrabble around behind your box in the dark trying to plug in a USB cable.some are located on the top of the base unit tower - no idea why they've installed ports there for
I agree with pandy, if the hub is not a powered hub then that's most probably your problem.
I've found that my unpowered hub handles a usb wireless dongle for my keyboard and a separate wireless dongle for my mouse.
Plug in my old 320GIG WD drive and the whole lot becomes iffy.
Tevion USB capture card not recognized (shows USB 2861 Video)
By retractOffer in forum Capturing and VCRReplies: 3Last Post: 4th Mar 2023, 11:38 -
USB-Live2 (Hauppauge) - Color issues with PAL VHS
By mondocamp in forum Capturing and VCRReplies: 20Last Post: 3rd Mar 2021, 17:52 -
Issues with Capturing D-VHS Through Thunderbolt 3 Port on Windows 10
By Ajace1000 in forum Capturing and VCRReplies: 4Last Post: 11th Jan 2021, 16:48 -
Victoria SSD USB port?
By BlurayHD in forum Newbie / General discussionsReplies: 0Last Post: 23rd Nov 2020, 11:40 -
4 port router + Switch, or 8 port router?
By sdsumike619 in forum ComputerReplies: 11Last Post: 12th Aug 2019, 12:48
