How do I export the command line for anything I put into clever ffmpeg gui?
Like this, for example.
[Attachment 76205 - Click to enlarge]
Results 1 to 21 of 21
Hi, if there is no option to export the command line and allso if it is not possible to copy the acctual text, if it is sort of "hard burnt" into the program and not the copy friendly version, there is such programs which make it possible from within this program interface easily select any open program and all "hard coded" text within any program will come up as copy friendly text!
Ive got one on my computer ill try find it and see what the name is since i cant remeber the name and i dont know where i put it!
I couldnt open the attachment and ive not used the cleverffmpeg either, hoping the response is still on topic! -
If you want commandlines use the internet and learn by yourself.
Otherwise use the GUI. -
How do I batch process videos in the gui with all of them having the same encoding settings?
Sorry for the delay, the program name was SysExporter, it is not the most good looking program but it is working pretty good! There is probably some other program around with better looks if you check around for it! From SysExporter it is possible to copy to clipboard and allso it is possible to select items and export it.
Well, normally when you add an video to an ffmpeg gui, it will automaticly generate an command line, if it is not possible to export it from within the ffmpeg gui, sometimes if it generate an hard coded command line that cannot be copied/exorted, this program will make it possible to copy/export it by selecting the program you want to copy hard coded text from (such as system messages or other parts of the program that you cant select/mark to copy it to the clipboard, for example an hard coded and generated command line from an ffmpeg gui). Basicly you just open the FFMpeg GUI + the SysExporter program and either select the FFMpeg GUI from the SysExporter's generated program list or by using the program selection tool that is avalible from within SysExporter. Once done with that you can select to copy the command line or to export it!
Like this?
[Attachment 76228 - Click to enlarge] -
Well - bit disappointing approach - use different GUI then - luckily there is more than one GUI for ffmpeg.
Btw It should be possible to get commandline for process - install some modern process explorer (i use https://learn.microsoft.com/en-us/sysinternals/downloads/process-explorer )and try to extract commandline directly from process. -
To be honest i can't recommend any ffmpeg GUI - almost never used any but on VideoHelp you have some recommendations on VideoHelp (programs section) and also forum members may be helpful on this.
Command line of process can be easily investigated in Process Explorer, run ffmpeg trough GUI then search for ffmpeg process in PE window - after hoovering on process its commandline will be displayed as popup - you can investigate it more thoroughly - just activate process properties and commandline is presented in tab 'Image' where it can be easily copied - hope it will work for you as it works for me - i use Win7 and PE version 16.21 . -
The answer is quite simple, read ffmpeg manuals, web manuals and most important web sites that specialize on coding solutions.
The most direct way is thru googling though.
Use some sites that are dedicated to coders, like stackoverflow, so for example google "stackoverflow ffmpeg encoding lossless png from video"
It is really simple as that, read searched results, read those pages, click on links etc., you have your line in no time.
How do I use QAAC AAC with FFMPEG command line?
By shampistols69 in forum Video ConversionReplies: 1Last Post: 26th Dec 2022, 10:20 -
Get the complete FFmpeg command line when using FFmpeg Batch Converter
By pascor in forum Newbie / General discussionsReplies: 8Last Post: 13th May 2021, 23:14 -
Need a command line for ffmpeg
By NTradd in forum Video ConversionReplies: 11Last Post: 14th Oct 2019, 11:25 -
ffmpeg command line help
By njscorpion in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2019, 12:42 -
FFmpeg does not convert file through command line
By Vidikon in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2019, 02:13
