Results 1 to 9 of 9
  1. Hi all,
    A little new at this, so just need a little help pointing me in the right direction.
    I'm trying to download a few episodes of Grand Design's Finland for example: https://www.mtv.fi/video/0283d75c6a72578e6642/jakso-2-ylellisyytta-lempaalassa - access to the website/stream is free via a free login.
    I've been able to figure out the url for the .m3u8 which is here https://vod.streaming.a2d.tv/f44ced16-5636-46a7-ba74-aa1f3a58f436/df41d8a0-7744-11ee-8...?start_index=3
    And if I use yt-dlp on that url with --allow-unplayable-formats I get what appears to be a video mp4 and audio mp4
    I've obtained the decryption key, which does work on the video file using mp4decrypt --key <key> vid.mp4 vid-d.mp4 , however when I try to do the same on the audio mp4, it doesn't do any processing, spits out a new audio file, but when I play it, there's no sound at all.
    Any ideas what i'm doing wrong? does the audio file somehow have a different decryption key? or is yt-dlp downloading/creating the audio file incorrectly?
    Any help is appreciated, thanks!
  2. not tested, but i think 1 key for video and 1 for audio
    if your streaming service it's free, share here login data
    also share pssh and your key found (with l3.py ? or ... ? )
  3. Hi, appreciate your reply, I was thinking maybe there might be another key, but couldn't find one from the EME data, i'm guessing it might show up elsewhere.
    You're welcome to login and have a look to see if you can figure it out for me, user account is
    l: altanderson@gmail.com
    p: V3%r%3Ei3qQR&tS
    Website is in Finnish, but you should be able to figure it out without google translate.
    I got the PSSH from here
    [EME] MediaKeySession::generateRequest
        Session ID: (not available)
        Init Data Type: cenc
        Init Data: AAAAdXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAFUSEJmQomaA+T4JpVq/NacNgGUaCGNhc3RsYWJzIihleUpoYzNObGRFbGtJam9pZEhadFpXUnBZUzB5TURNeE9EVTJOeUo5MgdkZWZhdWx0SPPGiZsG
    Key I got was
    SUCCESS
    KID: 9990a26680f93e09a55abf35a70d8065
    License URL: https://lic46.drmtoday.com/license-proxy-widevine/cenc/?specConform=true&assetId=tvmedia-20318567
    Acquired At: 1/15/2024, 8:58:38 AM
    9990a26680f93e09a55abf35a70d8065:d8c905107605f0fd3d81aa71502c02d6
    Hopefully that's all for the right video, I was changing between a few trying different things.
    Thanks for your help!
  4. try using N_m3u8DL-RE & m3u8 edit to mpd
    N_m3u8DL-RE -M format=mp4 --key 9990a26680f93e09a55abf35a70d8065:d8c905107605f0fd3d81aa71502c02d6 "https://vod.streaming.a2d.tv/f44ced16-5636-46a7-ba74-aa1f3a58f436/df41d8a0-7744-11ee-8015-01dadb48e460_20318567.ism/.mpd" --save-name video
  5. You have the correct key, but you need to use shaka-packager instead of mp4decrypt:
    packager --enable_raw_key_decryption --keys key_id=9990a26680f93e09a55abf35a70d8065:key=d8c905107605f0fd3d81aa71502c02d6 stream=video,in=video_enc.mp4,output=video_dec.mp4
    Combine it with N_m3u8DL-RE for a much smoother process:
    N_m3u8DL-RE --key 9990a26680f93e09a55abf35a70d8065:d8c905107605f0fd3d81aa71502c02d6 "https://vod.streaming.a2d.tv/f44ced16-5636-46a7-ba74-aa1f3a58f436/df41d8a0-7744-11ee-8015-01dadb48e460_20318567.ism/.m3u8?start_index=3" --use-shaka-packager
  6. Awesome, thanks jckzz and stabbedbybrick! Got it all working now Appreciate your help.
  7. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    It works for mp4decrypt if you do --key TRACKID:KEY instead of KID:KEY. I extracted the audio, checked with mediainfo,that trackID for audio is 1 (i've seen sometimes it being 2 or 4).
    Input:
    mp4decrypt --key 1:d8c905107605f0fd3d81aa71502c02d6 audio.m4a audio_decr.m4a
    And it plays the audio just fine.
  8. Thanks Sviests, I didn't know you could do that with mp4decrypt.
  9. Hi everyone, I have a similar problem but with AMZN, the video is all ok but the audio is not working, can anyone give me a suggestion? Thanks
